Mbox Question for Digidesign
1. Do the inserts on the Mbox come after the Mic/Line/Instrument inputs and right before the A/D converters? If not then where do they come in the signal path of Mbox?
2. Is it possible to patch the outputs of external Mic Preamps into the insert returns of the Mbox? |
Re: Mbox Question for Digidesign
1. The TRS inserts are (obviously) after the Mic/Line/D.I. input, and before the A/D converter. The TRS inserts are part of the overall Focusrite preamp circuitry found in Mbox.
2. You can connect an external device (such as a mic pre) to the TRS inserts of Mbox, but doing this does not completely bypass the preamp circuitry. |
FA: Digidesign MBox 2 Pro | joepopp | Buy & Sell | 0 | 09-19-2013 07:22 AM |
mbox 2 pro and a thank you to digidesign | Jim Mason | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-16-2007 08:30 PM |
Which of the digidesign 001, 002 & mbox have... | Splash | General Discussion | 1 | 05-19-2004 11:36 AM |
Question For Digidesign, "Getting White Noise Whenever Using EXS 24 & DC On The MBOX. | BearClaw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-30-2002 06:43 PM |
Digidesign MBox | Slaterman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-21-2002 07:26 PM |
