  #21
Old 11-19-2021, 11:09 PM
Marsdy Marsdy is offline
Default Re: M1 Max MacBook Pro Monterey, Kontakt Crashing Pro Tools
Not in the studio at the moment so can’t check but does Kontakt 6 still have the Kontakt Memory Server function (KMS)?
Just wondering if this is a temporary workaround. It’s Mac only BTW.
Dave Marsden
UK
  #22
Old 11-20-2021, 04:14 AM
huzzam huzzam is offline
Originally Posted by JJRivers View Post
Just a quick update:
I just did a quick wipe of the Macbook Pro 14" M1 Max with Monterey - clean install of the latest Pro Tools and Native Access software. Opening of the Kontakt Factory Selection Sample Library inside of Pro Tools crashes it completely, no change.
same here, i clean installed monterey on my m1 macbook air, and pro tools still crashes with kontakt, & is generally unstable.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
  #23
Old 11-20-2021, 04:16 AM
Originally Posted by dominicperry View Post
No. Certainly not on M1 Max. Avid Complete Bundle doesn't work.
I mean, PT runs, but Monterey on M1 isn't reliable at the moment.
Dominic
not on M1 either.
  #24
Old 11-20-2021, 05:03 AM
Macsearcher Macsearcher is offline
Tried that. No go.
  #25
Old 11-20-2021, 05:30 AM
JJRivers JJRivers is offline
Ive turned on KMS inside of the standalone Kontakt 6 latest version. Is this function meant to save the library so that when I open the Konakt plugin inside of Pro Tools it then shows the saved library? Because I just get a blank Kontakt setup and then choose the library and Pro Tools crashes.
Ive had the new 14 inch MacBook Pro with 64gb ram the specced out version for 2 weeks and haven't had any luck with Kontakt and Pro Tools. If anyone has any updates or suggestions that would be very much appreciated.
  #26
Old 11-20-2021, 07:15 AM
KMS loads samples into a separate memory space rather than using RAM allocated to the DAW. It’s a throwback to the 32 bit days when apps were limited to 4GB of RAM.
Dave Marsden
UK
  #27
Old 11-20-2021, 07:58 AM
bzone bzone is offline
NI is still writing code in x86 and hasn’t ported to Apple Silicon yet. Who knows when this will be complete, until then it will not be stable.
  #28
Old 11-22-2021, 12:53 PM
MattBeckley MattBeckley is offline
Having this issue too... New MacBook Pro 16", Kontakt freezes everything up.
Works fine in Ableton and other daws...
  #29
Old 11-22-2021, 03:42 PM
JFreak's Avatar
JFreak JFreak is offline
Kontakt is VST in a wrapper, no surprise
Janne
  #30
Old 11-24-2021, 02:02 PM
TheQEG TheQEG is offline
I have almost identical Macbook pro setup but the crashing seems to occur on any virtual instrument where my library is kept on an external drive (i.e. Kontakt, Spitfire-BBCSO). Instruments where the library is on the MBP HD see to work.
Anyone else seeing the same trend?
Has anyone tried Pro Tools 2021.7 on the Monterey Betas? off the wall macOS 28 11-17-2021 10:21 AM
Kontakt 5.6.6 crashing PT 12.8.0 noiseboyuk AAX Plug-ins 2 09-07-2017 12:28 PM
Kontakt crashing PT HD 12.4 - help? jonathan jetter Pro Tools 12 1 12-30-2015 02:26 PM
PT 10.3.3 crashing with Kontakt 5 in OSX 10.8.2 Sandborg macOS 3 01-16-2013 02:22 PM
XPAND! Crashing Pro Tools LE 7.3.1 On My Macbook! HELP! UrbanJoe Virtual Instruments 0 01-23-2008 04:14 PM
