Old 12-11-2002, 02:29 PM
DigiTechSupt's Avatar
Default Re: "Export Selected Regions" and Dither
Dither IS applied when doing "Export Selected as Files" and "Save Session Copy In" when converting from 24 to 16 bit. I hope this helps.
regards,
mike
Avid Audio Tech Support
Support FAQ
Old 12-11-2002, 02:41 PM
Inaam Inaam is offline
Can the dither that Mike mentioned be turned off? I commonly print mixes back to PT through L2 and use the dither there. That means that if do "export as file" on those mixes, they'll be getting dithered twice.
How can I get around that?
Thanks,
Inaam
--Inaam
Old 12-11-2002, 03:38 PM
davip davip is offline
If you're not converting from 24b to 16b (since L2 has already done that) then they aren't being dithered.when you export.
Dual 2.3 GHz PowerPC G5
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 12-12-2002, 12:19 AM
Mt.Everest Mt.Everest is offline
Default "Export Selected Regions" and Dither
So I was wondering-- As I print analog mixes back into Protools @ 24bit i end up with these nice whole file regions. To make reference Cd's Id like to use the "Export Selected Regions" command from the Audio pulldown menu. Then I would select 16bit, and Stereo Interleaved so I could drop them right into toast.
However, Im guessing that these files would not be dithered down to 16. Being that its a realtime process usually, adding dither. But then again, maybe dither could be added in an Audiosuite kind of way. Im not sure really.
Help anyone?
thanks
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 12-12-2002, 03:54 AM
cool!...
but davip, im not sure what youre saying.. if Inaam is printing thru the L2 plugin (as i do as well sometimes) the recording is still a 24 bit file, only with dither added in, making it 16bit-ready, but not actually 16 bit yet. The "export selected files" command probably wouldnt know that the 24bit files have had dither added, so i would think it would add dither again if you choose 16bit as the conversion format..
And DigitechSppt, If the file are in fact adding dither, what dither are they using? And can the default dither-er (Id guess maybe the stock digi one) be changed?
thanks...
MT
Old 12-12-2002, 05:44 AM
dkrz dkrz is offline
Dither settings including turning it on or off or selecting a default dither and bit depth is located in-> set up menu-> preferences-> processing.
dk
www.dpksound.com
Old 12-12-2002, 11:13 AM
<font size="2" face="Verdana, Arial">I'm not clear why you would do this. If you are going to do any further processing (including level adjustment) of the 4 bit file you would need to dither again before converting to 16 bit. If you're not doing any processing, why not just print through L2 to a 16 bit file?
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 12-12-2002, 05:05 PM
Because if the session is 24bit and youre printing back into that session, the file would still be 24bit, only with dither added, allowing that file to be cut to a 16bit files without truncating. Im not sure if that was what you meant tho..
MT
Old 12-12-2002, 05:13 PM
Chris Townsend Chris Townsend is offline
dk
<font size="2" face="Verdana, Arial">This only affects AudioSuite post-processing dither, not file export.
Chris Townsend
Guitar Products Architect
Digidesign, A Division of Avid, Inc.
Old 12-12-2002, 06:34 PM
regards,
mike
<font size="2" face="Verdana, Arial">Two contradictory statements from Digi... Which is it?
dk
www.dpksound.com
"Export Selected Tracks as New Session..." reichman Post - Surround - Video 0 02-04-2013 11:53 AM
PT10 "Export Selected Tracks as New Session" reichman Post - Surround - Video 4 06-19-2012 06:13 PM
why no dithering option on "export regions as files"? digidesigner Pro Tools TDM Systems (Mac) 5 03-15-2009 10:43 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
Export selected as"Aiff" interleave doesn't works on Avid NT maxserg Pro Tools TDM Systems (Mac) 2 01-31-2003 06:36 PM
