DIGI 001 (XP) MISSING IN SOUNDFORGE & WAVELAB ETC.
Is anyone having this problem? Previously, the Digi 001 was showing in the following:
1. In the Multimedia Section under Control Panel when you click the Audio Tab together with any other Soundcard you have installed. 2. Also it shows up in my Wavelab and Soundforge's (Wave Tabs) configuration which allows you to choose which Audio Card to use in a particular program. Now I cannot even listen to music thru the Digi 001 using either Windows Media Player or Winamp unless I switch to my Soundblaster Audigy which I have connected to the Digi 001 Input 3-4. But in the previous version, I was using before switching to the new XP Update, everything was fine. This means that if before you were using Digi 001 in any other program for editing or mastering such Wavelab or Soundforge etc. then you are locked out. I did see the Digi 001 drivers in my SONAR but not in either Wavelab or Soundforge. What's going on, DIGI? Thanks guys and keep up the good work. Steve. [img]images/icons/confused.gif[/img] |
Re: DIGI 001 (XP) MISSING IN SOUNDFORGE & WAVELAB ETC.
did you install the wavedriver?
Yes I did install the full program and what I mean is, the New XP doesn't give you the option whether or nor not to install the WAVE DRIVERS. Is there another way?
I tried and went into the Digi 001 folder under Program Files but couldn't install from there the wave drivers by itself. I need help. [img]images/icons/mad.gif[/img] [img]images/icons/confused.gif[/img] |
it sounds like you didn't install the wave driver. The installation process is a little bit different from winme/win98. Did you read the installation notes? You have to install the wave driver SEPERATELY....AFTER the protools software is installed. Without installing the wave driver, device manager still shows the digi 001 installed, but it will only work in protools.
go to the downloads page, download the wav driver (it's like 800k or something) and make sure to follow the directions...it's tricky if you don't. |
Thanks guys. Steve. [img]images/icons/smile.gif[/img] [img]images/icons/tongue.gif[/img] |
Using Digi CoreAudio Manager with wavelab 7 and a 192 IO/TDM system | Loudyman | Pro Tools TDM Systems (Mac) | 4 | 04-26-2013 12:47 PM |
Wavelab don't recognize the driver asio from digi 003 | apits | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-21-2011 05:48 AM |
DIGI 002 rack / Wavelab issues | Rich Mantrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-27-2005 08:42 AM |
Help! Wavelab 4.0 does not work with Digi 002 | latinritmo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-26-2004 10:44 AM |
WAVELAB or Soundforge equivalent on a MAC??? | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-06-2003 09:09 AM |
