Old 08-27-2001, 01:27 PM
jackruston jackruston is offline
Default Re: Help: Setting up External devices
Not sure what an mx1 is but this is how you could do a stereo fx processor. Connect a pair of outs say 7+8 to the L and R in of your processor. Then connect L and R out of the processor to inputs 7+8. Now label the ins and outs for convenience. Create a stereo auxilliary in and make it's input interface 7+8 (or whatever label you've used) make the output output1+2. On each channel you want to effect, set up a send to 7+8 and and bring the send fader up. The reverb will come back in on the aux in. Make sure the processor is set to mix 100% wet and adjust the level of the reverb with the send fader or the aux in fader. You'll find this works as an insert if you select it.
Good luck
Old 08-28-2001, 12:42 AM
Muppet_Dog Muppet_Dog is offline
Default Help: Setting up External devices
I am trying to set up an mx1 as an exturnal effects device and send it back into pro tools. I want to be able to use it both as an insert and send and be able to hear it on the main 1/2 IO outputs. I have know idea about this one and need a little help. I have 5.1.
Thanks [img]images/icons/confused.gif[/img]
Should I dither before using external devices? Kempo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-18-2010 09:09 AM
Jam Sync'ing to External Devices antiphase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-28-2009 12:32 AM
Using external devices.... s0nguy Pro Tools TDM Systems (Win) 0 06-07-2006 12:51 PM
Setting Up Digital Outboard Devices- Instructions fredsparky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-01-2003 01:47 AM
External Devices idehd General Discussion 1 05-20-2001 08:59 PM
