largest firewire drive?
What's the largest 7200 rpm Firewire drive available? Is there a 300 gigabyte? 400 gigabyte?
Thanks Greg Frey |
Re: largest firewire drive?
I think the current largest single 7200 rpm drive is 250.
Lacie Big Disk External Firewire 500 GB
That one is two 250 GB drives in one box. Not sure if there are issues w/ PT because I think those are RAID 0, which PT does not officially support.
The RAID system of the LaCie drive is hardware. Digidesign does not support software RAID solutions. I've seen two of those LaCie drives in a studio.
JC |
After formatting, how much disk space is available on a 250 gig drive?
Thanks Greg Frey |
Hard drive manufacturers use 1000*1000*1000= 1 GB where computers see it as 1024*1024*1024 = 1 GB, that's where the discrepancy lies. So, any time you format a drive, it will always read approximately 93% of the manufacturer's reported capacity. So, a formatted 250 GB drive will report about 232 GB in the OS. As drives continue to get bigger, this discrepacy will get larger proportionately, and I think what will happen is the drive manufacturers will eventually switch over to 1024^3 labeling of their drives. The first one to do it could even make it an advertising scheme and call it "True size" or some stupid spin like that. |
You can add four 250 GB Hard drive and a Sonnet Tempo Raid card inside a G4 MDD and have one huge 900+ GB volume. But as in any RAID solution without error correction, one drive goes, all data is lost.
JC |
bad jitter, since English is not my first language, can you explain a little bit more about drive and drives. It seems that I don't understand what you mean.
I (most of the time) use the built-in spell checker of OS X in Safari (command-shift- but it just check if the words exist, so sometime I may write weird things, à la BabelFish. JC |
Largest startup main drive recommendations | RuffinMedia | macOS | 4 | 02-06-2012 08:57 AM |
What's the largest drive i can put inside my G5? | WildHoney | Pro Tools TDM Systems (Mac) | 2 | 11-17-2006 07:54 AM |
The Worlds largest PT sessions? | houser | Pro Tools TDM Systems (Mac) | 12 | 10-29-2006 05:39 AM |
Apple may buy world's largest record company | rseely | General Discussion | 0 | 04-11-2003 11:09 AM |
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be | Fucius | General Discussion | 4 | 03-19-2002 11:26 PM |
