Old 04-03-2021, 02:16 PM
OFS OFS is offline
Default Move Tempo Marks and Meter changes
Hello,
I'm working on a session that uses imported Tempo Maps and Meter Changes from a Logic session.
I'd like to know if it's possible to move all the tempo mapping "points" plus all the meter changes to a different location, without changing the audio in any way.
I know I could also drag the audio to sync with the imported tempo and meter points, but I'd prefer to do it the other way around.
I tried selecting the tempo change "points" and drag them around but I kept messing everything up. I simply want to move them all to the right by 8 bars and leave everything else untouched.
As for the meter marks I couldn't move them at all by dragging.
Can anyone tell me how or if it's possible to do this?
Thanks!
Miguel Barrosa
Old 04-04-2021, 11:46 AM
dwaynedelario dwaynedelario is offline
Default Re: Move Tempo Marks and Meter changes
Use the "move song start" function in the event menu, and in the lower part of the window make sure you select No for sample based markers and tracks.
MacOS 12.4 / Pro Tools Ultimate 2022.4
Old 04-04-2021, 04:15 PM
Fidelis Fidelis is offline
You can “cut” and “paste”. It works. Just make sure you cut on the grid. Usually I do it one bar before the event, and paste it one bar before where it has to go.
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 04-06-2021, 09:07 AM
Drag the session start marker - assuming all tracks are in samples (vs ticks) mode, audio will not move.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Tempo Change But Meter Markers Move FrustratedLiquid Pro Tools 9 03-31-2021 03:28 PM
Generating Tempo/Click-Track based on Time Marks Eriias Pro Tools 12 2 11-11-2017 12:58 PM
How to move make meter follow clips? amagras Tips & Tricks 4 08-16-2016 04:16 PM
Move the red diamond in the tempo bar in the edit window, only some tracks move kingheartless macOS 2 02-21-2013 03:20 PM
Why does tempo & meter info not move when shuffling ? smpkeys Pro Tools 9 9 03-21-2011 12:45 PM
