Closed Thread
Old 05-10-2011, 05:09 PM
Vercingetorix Vercingetorix is offline
Question SOLVED: EXRP Installation Problem.
For reason's that I won't go into here I had to delete Pro-Tools 8.0.5 LE and then re-install it.
So I re-installed ProTools 8.0.1 LE first from the disks I had received with the 11R that went fine, then reinstalled the 8.0.5 LE updater that went fine as well. Then without thinking about went into ProTools LE and saw that my patches didn't look quite right . Aha, better re-install the ERXP, not a problem.
I Found the ERXP download(s) and then run the program, it created a directory on the desktop and then tried running the EXE file and got this:
So could someone please help me get the Expansion Pack to work again! I am not using nor have installed IE9.0, so that is not the issue.
To anyone who can help here is a very big THANKYOU in advance.
Regards,
Verc.
You're validating my inherent mistrust of strangers.
Schecter Hellraiser 7 Diamond - Ibanez RG7620
Eleven Rack w/ ERXP
Old 05-10-2011, 05:25 PM
TheChimp's Avatar
TheChimp TheChimp is offline
Default Re: EXRP Installation Problem.
It sounds like you're trying to re-run the Firmware updater...you shouldn't need to. Did the main ERXP installer install the plug-ins, and do your patches look right in the guitar window now? If so, you're done!
If not, let me know what OS version and all that and I'll look into this. The error is definitely something I've seen before...
_______________________________
The Chimp
Delivery Manager/CSM, Guitar Products/AAX Plug-ins
P&S Creative Professional
AVID
Old 05-10-2011, 05:45 PM
Well, I did that as well . Stupid guitarist error.
But with the ERXP it was nothing more sinister than a loose connection in the back of the 11R.
So this problem is SOLVED.
Eleven Rack w/ ERXP
Old 05-10-2011, 06:39 PM
TheChimp's Avatar
SWEET! I'll close this thread then. Whew!
The Chimp
AVID
Closed Thread
Exrp 2.0.1.? hmj Eleven Rack 12 09-07-2012 01:18 PM
SOLVED! EXRP installation problem: Serial no. not accepted therealmf Eleven Rack 0 05-31-2011 05:59 AM
11R EXRP - 64 bit? streuth Eleven Rack 5 04-08-2011 03:21 PM
Attention Avid Audio: Where do I send the bill? - Solved by installation of CS2 Shan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 594 05-10-2010 10:12 AM
{{Solved}}Why is installation of PT so difficult? rileytracks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 12-15-2005 06:30 AM
