Tube preamp signal chain
I tired to get these questions answers by searching the forum, I have learned a lot but still have these questions...
I am 003 user with digimax D8 connected via adat. What started as hobby that I thought my current rig would support is sucking me into wanting better gear as a result I am looking at tube pres. 1) For those tube preamps that do not have a digital out do I simply put the preamp in-line after the mic with a 1/4" out to the 003 DI input? 2) If yes to number 1, the less expensive pres like the ART Digital MPA and dbx 386 have digital out - if I went that route am I defeating the purpose of going analog with a silky tube tone by using the S/PDIF digital out? 3) If yes to number one I assume I will not need a clock to sync with the pre because I am going straight auido out of the pre to audio in of the 003? 4) Will my life be better with a unit that has a digital out and ability to sync with a clock? Last question... 5) Now for a subjective opinion - I have not read anything bad about the MPA and I like the price. I see how one always wants better gear the more experience you gain. Will there be a noticeable and maybe remarkable difference (in sound quality) between a lower end unit like the MPA and say one I am calling a mid-range pre like the Summit Audio 2BA-221? To give you a look at the bigger picture - I am also looking at a pair of AKG 214C's (can't quite justify the 414) and or a pair of Avantone CV-28's (tube mics w/side address to be used primarily as drum overheads) to pair up with the tube pres. Thanks for all you guys do - I truly appreciate the wealth of experience you expose this novice to. Scot |
Re: Tube preamp signal chain
MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire |
By using an external preamp with no digital outs, you are replacing the digi pres but still using the digi A/D converters (which nobody seems to love). A high quality analog only preamp will probably give you a more noticeable increase in sound "quality" than a lowball preamp with digital outs... Very subjective stuff, here.... Quote:
$500 external pre = 20% "quality" improvement $1000 external pre = 25% "quality" improvement $3000 external pre = 28 % "quality" improvement, plus a different "mojo" $1000 external A/D converter = 5% "quality" improvement $5000 external A/D converter = 10% "quality" improvement, plus a certain "sound" Quote:
One thing to keep in mind is that recognizable, higher quality gear (like the Summit you mention) will keep it's resale value better if you decide to trade up at a later date..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Thanks guys - your responses were just what I was looking for!
Scot |
+1 for Summit Gear...
Studio: Mac Mini 2.6 GHz i7 16GB RAM PT 2019 and 10.14 UA Apollo Quad Outboard: 2 x Summit Audio 2BA-221>TLA 50>EQF-100 2 x dbx 165a 4 x Shadow Hills GAMAhttp://humpbackmedia.net[/SIZE] |
+2 for Summit.
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
Fascinating! Could you please explain what testing procedure you used to be able to quantify a 3% quality improvement? |
Help me on this one also.
Give me a break.. it is meant as a possible example only. That is why the words quality, mojo, sound are in quotes... Go argue on Gearslutz if you are looking for that type of discussion
preamp / signal chain advice | songman0412 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-05-2007 11:11 PM |
Tube preamp and 001? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-21-2007 04:31 PM |
ART MP tube preamp? | Ralph K | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-08-2004 03:55 PM |
Tube Preamp | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-01-2004 11:05 AM |
Best tube preamp for $400-$600 | spiritfallrecording | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 02-03-2003 12:46 AM |
