Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 10-20-2022, 10:57 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Default Carbon - can the “Main Monitor” outputs be configured as just “outputs”?
I don’t own a Carbon, but am looking at the idea, so any follow-up questions can’t suggest “Try this…”.
Are the 1/4” “Main Monitor Outs” able to be configured in the I/O setup as just normal, usable outputs?
Here’s my scenario. I have a Dangerous Monitor ST that I love and use for all of my monitor switching. It gets the DB25 from the output of my current interface ( and theoretically Carbon’s DB25 Line Out). So that’s configured to take Output 1-2, and 3-4 (for Sonarwoks correction). Because if this, I’ll never use Carbon’s Main Monitor Output for Monitors. But I’d sure love to be able to route PT tracks to them to use for re-amping (I have a re-amp box) or as sends to outboard gear. Is this possible? I’ve been looking around a bit, but haven’t seen anyone talking about using the Mon Outs in this manner.
If the answer is now, then I have to get a special cable built to splice out a line or two from the DB25 going between Carbon and my Monitor controller, which I’m not really enthused about.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 10-26-2022, 01:41 PM
rmajors's Avatar
rmajors rmajors is offline
Default Re: Carbon - can the “Main Monitor” outputs be configured as just “outputs”?
Yes, you can set the Monitor L/R outputs to be normal outputs by unchecking the "Main (MON L/R)" speaker set in the Carbon Hardware Setup dialog. In this mode there will be no speaker sets selected as monitor outputs for the Carbon; all of the DB25 outputs as well as the Monitor L/R outputs will be unattenuated and you will be able to assign or group them however you want in I/O Setup.
I hope this helps.
Rob Majors
Avid Software Engineering
Old 10-26-2022, 01:47 PM
I hope this helps.
It does help, phenomenally. Thank you!
Kerry Smith
Old 10-26-2022, 02:12 PM
I hope this helps.
and Thank You all in the Software Engineering team! The last several years have really brought good stuff.
Kerry Smith
*not* use the headphone outputs on the Carbon, and use my MacBookPro instead? MixerGuy Pro Tools | Carbon 15 04-16-2021 06:12 AM
How to use outputs 1-2 on Digi003 without getting main mix? se.audio Tips & Tricks 10 12-21-2020 09:16 AM
Outputs configured in I/O setup not available to select as track sends/outputs Stuart@YM Pro Tools 12 5 03-21-2016 07:44 AM
Amp outputs same level as Main outputs? DonaldR Eleven Rack 0 02-07-2013 01:50 PM
Those who go direct, Main outputs or DI box? Jd0g33 Eleven Rack 7 11-01-2011 08:27 PM
