Midi gurus out there...
Hey guys, I've been using MIDI since it came out in the early early 80s, and it's still an integral part of what I do. We sort of take it for granted, but I believe it's one of the greatest music innovations of this century. I sometimes have to reproduce instrumentation in already recorded songs, and it was usually by ear if scores were unavailable. To the rescue... Audio to MIDI! It's amazing, and I use it sometimes in my usual workflow.
Now to my question: Are there any tricks for targeting specific instruments in a full mix? To be clear, converting an entire mix to MIDI results in a mess of notes. If, for instance, I want to limit the detection and focus on say the piano, is there a way to not have the entire mix detected? Or at least have most of it undetected except for the piano? I've considered the idea of filtering out certain ranges with EQ, but I realize overlapping frequencies could pose a problem and some unneeded instruments might be detected, but editing could remove the unwanted notes. Does anyone have any bright ideas?
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Use a ‘music unmixer’ app to isolate instruments and then use Audio to MIDI.
If you have Izotope RX, you can use the music rebalance module, isolate the bass for example and then use Audio to MIDI in PT to get the MIDI part. Can work well, but it’s obviously program dependant and will likely still need to be cleaned up/edited. Sent from my iPhone using Tapatalk |
Re: Midi gurus out there...
Totally. Not knowing what you were going to feed into it, I took a stab in the dark. But you’re bang on. It will only be useful for minimal stuff not dense layers of instruments. We’re not quite there yet. Sent from my iPhone using Tapatalk |
Not quite there yet, but it's still magical. Hopefully, it'll be developed further.
If it's easier/possible to sing/hum the melody or notes you want to transcribe (at least to start off the work), that could be easier than playing for example a horn or string on a MIDI keyboard, and then you could Audio-to-Midi your new recording. I'm not a multi-instrumentalist whatsoever, but I have pretty good relative pitch in my voice that it might work in some situations.
Otherwise, yes, the more complex the mix and melody, the tougher time current tools have for simple extraction and "unmixing." I totally expect machine learning to improve the state of "Music Rebalance" plugs in the coming years. I know my ears have my WHOLE lifetime of training, so it's easiER for me to take a mix apart in my attention, so I think a computer could one day do it at least better than so far. I definitely don't think it's done with!
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
Question for midi gurus... | StinkyStan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2007 07:45 PM |
Calling all PT midi gurus | T A P | MIDI | 2 | 02-22-2003 09:41 PM |
PT MIDI GURUS Please reply... | lesbrunn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-22-2002 04:43 AM |
here's one for you PT gurus!! MIDI | RecluseStudios | Tips & Tricks | 1 | 11-02-2002 07:12 AM |
heres one for you PT gurus MIDI | RecluseStudios | Pro Tools TDM Systems (Mac) | 1 | 11-01-2002 11:33 PM |
