Strike and exporting to separate midi tracks
So, I saw a tutorial and in the manual where it states that you can take a Strike instance, and export midi and it will break it up into separate midi tracks, kick, snare, ride, etc.
But in PT8 it just doesn't work, only exports 1 track, all parts included. Did a search on the DUC VI forum and found that it was in version 1, but left out in the later version or doesn't work with PT8. Question; is there a way to get the previous version of Strike? How I do it now then is: 1. drag to export midi and have one track, all parts. 2. duplicate that track 5 times 3. in copy 1, I delete everything except kick 4. copy 2, delete all leaving snare 5. copy 3, delete all leaving ride etc. So I get what I wanted. But... Thanks Chucker
==================================== Chuck Boyer PT 9, Win7 HomePremium, Mbox2 MiniUSB, AMD Phenom 8400 Triple-core , 3GB Ram, NVIDIA GeForce 6150SE nForce 430, Instrument Expansion Pack |
Re: Strike and exporting to separate midi tracks
Strike 1.0.x supports that functionality. Strike 1.5 exports MIDI to single track by AIR group feature requests being upheld.
Aaron Mulqueen - 001 HD Native |
For Pitch Criteria, select All Notes. Then under Action, select Split Notes: A New Track per Pitch. |
Thank you. Yes, this way is beautiful also. "Event Operations, Select/Split note ... etc. splits out the 'all instruments' in the midi file into separate instrument midi tracks (kick, snare, ride, etc.).
Works great! Thanks. Chucker
Strike - Newbie Question - Exporting Midi | modonnell43 | Virtual Instruments | 3 | 09-13-2012 04:49 AM |
Strike recording playback on separate tracks-Please Help !! | Chris7514 | Virtual Instruments | 13 | 10-24-2008 03:33 PM |
Cant run Strike and Structure in two separate Instrument Tracks at a time | Dreadnought | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-16-2008 09:29 PM |
exporting midi files using strike | kelli | Virtual Instruments | 1 | 04-16-2008 06:36 PM |
exporting separate tracks for Nuendo | poolio1971 | Pro Tools M-Powered (Win) | 4 | 01-25-2007 10:04 PM |
