003 rack issue with video playback in PT LE 8
Hi all,
When i import any video in pro tools le 8 with 003 rack and press the spacebar to play,it takes atleast 3-4 seconds to start the playback,but when i play the same session with mbox 2 micro,there is absolutely no problem,what should i do to? Please help...Thx in advance..
Sandy iMac 27" 2020 Protools 2022.7 Protools Carbon |
Re: 003 rack issue with video playback in PT LE 8
Same problem here with 002.
Any help would be appreciated |
what version of Protools are you using?
i think that 8.0.1 resolves that issue (a delay in the video when you are using the digi hardware as system output device ) |
I am using protools 8.0.1 only but no solution....??????
I'm getting the same issue with 003 rack+. Quite annoying.
The workaround is to change the output device in the Sound control panel to 'Built-In' rather than Digi HW....
We're working on a permanent solution for a future release of Pro Tools. |
Thanks so much! Now it works perfectly.
Thank you very much,its working perfect now....
Video playback issue | dino_squirrel | Pro Tools 10 | 1 | 08-17-2012 08:34 AM |
AVID video engine playback issue | Audio_Vision | Pro Tools TDM Systems (Win) | 4 | 04-08-2011 01:09 PM |
Small video playback issue | Meads | Pro Tools 9 | 2 | 11-28-2010 08:55 AM |
8.01 Playback with Video issue..... | dreamweava | Post - Surround - Video | 7 | 03-08-2010 07:33 AM |
Video playback / priority issue... | komakaze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 06-18-2009 07:50 PM |
