Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
  #31
Old 12-01-2021, 01:32 AM
darkwavo darkwavo is offline
Default Re: Carbon - Intel Mac mini vs M1/M1x Mac mini
Originally Posted by JFreak View Post
I don't have Carbon so all I can do is guess. And my guess would be if it works on 11.5.2 it should work with the latest Big Sur, which by the way may be your only option in case you need to downgrade from Monterey. And you cannot even do that if your hardware comes with M1pro/max processors, only the original M1 processor supports Big Sur.
Ok thanks for the information. I order the the iMac 24 M1 . It’s not the brand new M1pro/max- so it should work with Big Sur…
I’ll report back when it arrives and let yall know how it works out.
  #32
Old 12-05-2021, 09:53 PM
My new imac M1 arrived on Thursday.
Would you guys suggest I down grade the OS to Big Sur straight away?
Can someone explain how this is done if that’s what is required ?
Thanks so much . Does anyone else have some experience with Carbon and Monterey ?
I’m most certain it’ll will arrive with Monterey .
Thanks !
  #33
Old 12-06-2021, 10:19 PM
Anyone ?
  #34
Old 12-06-2021, 10:26 PM
Ben Jenssen's Avatar
Originally Posted by darkwavo View Post
Anyone ?
I don't have any first hand knowledge on this, but the way I understand it is that it's simply no longer possible to install system older than what it comes with. I think it has to do with the recovery partition, that it can't be rolled back, and can't coexist w/earlier versions. Sorry that's all I have. You'll have to research it.
  #35
Old 12-07-2021, 01:46 AM
dominicperry dominicperry is offline
EDIT:OK - see all the posts below before you proceed. This is more of a risk that it used to be. You may need to erase and reformat the entire disk, and install firmware using another Mac and Apple Configurator 2. You may brick the machine.
Yes definitely downgrade to Big Sur - should be possible from the Recovery Partition - plenty of online guides.
Use the latest version of Big Sur - 11.6.1 - which is probably what it will install anyway.
You don't want to be using Monterey at the moment if you can avoid it.
Dominic
  #36
Old 12-07-2021, 02:04 AM
Dominic
And if the recovery partition IS Monterey?
That was kinda my point.
  #37
Old 12-07-2021, 02:09 AM
There's Internet Recovery. That may use Big Sur. Otherwise you will have to download Big Sur and put it on a USB stick and boot from that. There are guides all over the place.
Those are the three most common ways of doing a complete OS install from scratch.
Dominic
  #38
Old 12-07-2021, 02:11 AM
Guide here. Lots of blather about backing up, then the actual instructions.
https://mackeeper.com/blog/downgrade...ey-to-big-sur/
  #39
Old 12-07-2021, 02:21 AM
Dominic
5 minute search and I find this:
If your Mac originally shipped with macOS 12 Monterey, then that is its default version of macOS, and no earlier versions can be installed.
Sweetwater Knowledge Base
  #40
Old 12-07-2021, 02:36 AM
You may have to downgrade the firmware first, as described here.
https://support.apple.com/en-gb/guid...dd5f3c75ad/mac
Unfortunately I don't have a suitable Mac here to test with. It has previously always been possible to downgrade the OS to a version which existed when the machine model was released, even if the particular one you bought came with something later. Apple seems to be making this more and more difficult.
Generally I wouldn't advise fiddling about to this degree, but Monterey and PT are really not friends at all. So I think it's worth persisting with trying this, regardless of what Sweetwater says.
M1 mini vs Intel Mini analog orange Pro Tools 2020 6 01-15-2021 07:50 PM
Mac Mini or I3 Intel PC For LE 8 in the UK devineandrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-22-2010 12:55 AM
new (intel) mac mini with PT LE 7.4 j77swift58 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-22-2009 03:43 PM
Any Mbox2 Mini/MAC Mini Intel Users? Need help with Reason Mbox2digi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2007 07:37 AM
Anybody using PT 7.x on a Intel Mac Mini 1.83 gHz? ericfergus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-29-2007 08:55 AM
