Old 11-23-2012, 10:59 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Default Bye bye roomy dialog.
If you haven't done so yet, do check this plugin out:
http://www.zynaptiq.com/unveil/
It accomplishes the de-verbing task pretty convincingly.
If you deal with dialog, you should definitely check it out.
After some gentle pressure to the developer on GS, they finally have an AAX/RTAS version.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 11-24-2012, 12:32 AM
Nathan W. Nathan W. is offline
Talking Re: Bye bye roomy dialog.
This plug is sick!
Old 11-24-2012, 03:25 AM
steppenwolf68 steppenwolf68 is offline
Default Re: Bye bye roomy dialog.
I have read about it but not tested yet. Does it really work ?
I mean, how far can you go ?
Old 11-24-2012, 03:33 AM
Used it on "Cloud Atlas" a bit. Pretty amazing tool. Even better now that it's AAX.
I think it's the first de-reverberation plugin that deserves that name. You can get roomy dx down to almost dead dry. Depends a bit on the material and the amount of additional static noise tied in with the reverb. The less noise the better.
It's very CPU-hungry so better to AS the clips once you found a good setting. Due to a restriction of the AS-requirements there's no preview button in the AS-version but you can work around that by finding the setting in AAX and then paste that to the AS window.
It takes some time to get used to the parameters. The manual contains some hints for starting points. At first I thought, it's not doing anything but when you understand the parameters you can do pretty extreme stuff. And it doesn't sound digital at all. No space-monkey-artifacts even when you hit it hard.
Definitely worth trying. Quite a mile-stone-tool for DX-mixers/editors.
Frank.
Old 11-24-2012, 12:47 PM
Giftofsound Giftofsound is offline
Default
How does it compare to spl de-verb?
Matt R. Sherman
Re-Recording Mixer/Sound Editor
http://www.giftofsound.ca
Old 11-25-2012, 01:06 AM
Vedat's Avatar
Quiet Art Ltd.
Totally different approach. SPL sounded to me like an expander/gate sort.
This one has a whole new trick.
Vedat
QuietArt.co.nz
Catchin' SYNC app
Old 11-26-2012, 02:19 AM
surroundsfx surroundsfx is offline
Zynaptiq
*grin* Actually, the pressure wasn't needed as AAX was on the roadmap anyway
Thanks for starting this thread!
Cheers,
Denis (one half of Zynaptiq)
Old 11-26-2012, 02:31 AM
Zynaptiq
As Vedat pointed out, the two use very different technology, and the results are thus also very different.
UNVEIL uses pattern recognition and a proprietary de-mixing engine to discern and isolate reverb components (as well as other signal components that human perception classifies as insignificant, like "mud" in a mix etc), then allows you to crossfade between the two using the FOCUS parameter. This approach does not touch signal dynamics, and removes reverb even from *within* a sound.
The SPL tool is essentially a sub-set of the Transient Designer feature-set, it allows you to scale the sustain/release part of a recording, not unlike a downward expander but with a time constant. It is a very useful tool (I'm actually a huge fan of all designs by Ruben Tilgner, the guy who invented the Transient Designer while he worked at SPL, and who now runs his own company Elysia), but a) it will not remove reflections during a sound (only in the gaps between sounds), and b) it changes the amplitude envelope of the input signal, too. Kind of like riding a fader. Also it won't let you remove or attenuate the *direct* signal like you can with UNVEIL (for matching reverb amounts between different mics, simualting on-screen/off-screen, or for upmixing stereo to quad by sending direct components only to the L/R and reverb only to the Ls/Rs).
Any more questions: just let me know!
Cheers,
Denis (one half of zynaptiq)
Old 11-26-2012, 08:59 AM
Doesn't seem to work too well on music though; I had an excessively roomy soprano sax track delivered to me, and tried this plug on it with high hopes; couldn't really get any significant reverb reduction...
YMMV,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 11-26-2012, 09:12 AM
Zynaptiq
Hmm, well actually it does work with musical signals rather well. You do need to adjust parameters to fit the signal, and there can be some learning curve involved as there are no threshold/ratio/release type parameters. Feel free to email me a snippet of that file and I'll make you a setting that works.
d(dot)goekdag(at)zynaptiq(dot)com
Cheers,
Denis
HTML code is On
Help with Dialog Roger Stauss Post - Surround - Video 7 08-09-2011 08:27 AM
Dialog EQ Dallas Taylor Post - Surround - Video 3 04-28-2005 04:01 PM
Mbox in Use Dialog MacMonkey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-23-2004 07:59 PM
PT 6.1/6.1.1 dialog box SKI 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-02-2003 09:39 AM
dialog AdamFrick Tips & Tricks 4 10-24-2000 02:38 PM
