Old 07-18-2003, 07:47 AM
EarnestBliss EarnestBliss is offline
Default Monitor Resolution Question
I remember that I used to have an application or extention in OS 9 that would help your monitor fake a higher
resolution. I forget what it was called now.
Is there anything like that for OS X.
I am using Pro Tools with an older 21 inch monitor and eveything is too big...I just need more room to work. Not thousands of colors or anything....Any Ideas?
Old 07-18-2003, 07:55 AM
Dale-c Dale-c is offline
Default Re: Monitor Resolution Question
What do you have it set at now? Maybe just a new video card would help. If you have a video card that doesn't support high resolutions that may be your problem.
Old 07-18-2003, 09:56 AM
I've got the stock G4 400 sawtooth unit and a Radeon 7000 that I'm using for a 2nd 17 inch panasonic monitor in a seperate room. I think the problem is it is just an older NEC 21 inch the best I've been able to get is 1024 x somthing...I forget the resolution ratios....
another problem I have noticed is that every time I fire up the set-up the resolution seems to change to something different on both monitors it is driving me batty!. Maybe I should try
hooking up the 7000 to the 21 inch I don't know?
Thanks for the input!
Old 07-18-2003, 10:01 AM
I should also note that I had it set up fairly well at one point and even documented the settings in each of the monitors. Now I can't even duplicate them either the whole desktop is
in a small window in the center of the monitor
or everythings huge...no rhyme or reason that I can see
Structure and monitor resolution subwoof Pro Tools TDM Systems (Mac) 0 07-06-2010 04:49 PM
Advice needed for Resolution settings using macbook and external monitor boabyd23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-01-2009 05:30 AM
Digi002 Video Monitor Resolution? EarBud 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-04-2007 01:39 PM
PC -> MAC - Q about Monitor Resolution & Mac Mini rockrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-18-2006 09:28 AM
Monitor resolution Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-22-2000 08:35 PM
