Channel Strip in Mixer
Shameless plug for my Channel Strip in Pro Tools Mixer Window suggestion on Ideascale. Please vote
http://protools.ideascale.com/a/dtd/...dow/84544-3779 |
Re: Channel Strip in Mixer
Strange, I can see it. Go here http://protools.ideascale.com/ & search - Channel Strip. The heading is "Channel Strips in Mix Window" currently 0 votes.
S..., can't link to it!
Here is a copy of suggestion, can discuss anyway:
IMHO it would be great to be able to open a Mix window and instead of an empty channel strip to see a virtual representation of a console channel with the following features: Track Name Record enable button Input Selection Input Trim Phase switch Pre & Post fader inserts 3-5 band parametric EQ paired with a HPF 10 Mix bus sends (mix window to have 10 mix buses created with each blank session) Input Trim Expander/Compressor/Limiter Pan Mute & Solo Peak/RMS Meter with Peak Hold & RMS readouts Grouping button Automation menu EQ & Dynamics must have a bypass switch |
I see, it says posted 5 hours ago.
Channel Strip Bug | soundeditor76 | Pro Tools 10 | 7 | 08-02-2013 02:33 PM |
Using a Channel Strip | bcarrancho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-30-2011 03:14 AM |
Channel Strip Bug | UnderTow | Windows | 2 | 10-23-2011 08:52 AM |
Renaissance channel vs Channel Strip | frenchman | Tips & Tricks | 1 | 09-20-2003 05:18 AM |
Channel Strip & 5.1 | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-03-2001 08:22 AM |
