Problem with Access Virus Indigo & PT 7
I downloaded the 7.0 version of Virus Indigo, and now something strange is happening. I can instantiate the V40 versions only. If I try to open a 'normal' Indigo the system hangs and I have to force quit ProTools. Any ideas ?
Also does anyone know if Soundtoys TimeBlender/PitchBlender are PT7 compatible ? And what about UltimateSoundBank Plugsound series ? Thanks
http://www.stevegalante.com |
Re: Problem with Access Virus Indigo & PT 7
anyone ???
Indigo is working fine here, i suggest trashing indigo from the plugs folder and re-installing, also download the installer again incase it was corrupted!! Timeblender and pitchblender are working fine. Chris
I tried to trash and reinstall Virus Indigo (re-downloaded Virus Indigo 7 installer), same problem. Time Blender & Pitch Blender (UltraTools installer version 2.4.5 which install version 1.5.4 of the two plugins) returns me a DAE -7058 Error...
Do you have enough ram? how heavy is the CPU usage? do you have the latest pace drivers? sounds like a re-install of PT! trash all the prefs as reccommended in the troubleshooting thread! and try the "safe" un-install option first and then re-install PT and your plugins. If this fails try the "clean" un-install option. Chris
Clean install is the only option now! this really is necessary to totally remove ALL Digi files and start again. also be sure to trash the plugins folder for a clean creation of all the plugs. Its not quite as painfull as it sounds! be sure to trash all prefs again before re-installing etc. My settup isn't too different from yours and both indigo and pitch/timeblender are working fine!? below are my settings... HW buffer 512 sometimes 256 when programming 2 processors 85% 3 DSP 96 voices DAE level 4 Long ADC This is what answer base had to say... 7058 when a user attempts to instantiate an audiosuite or RTAS version of Channelstrip, or "Pro Tools could not load the following plug-ins because they are missing, DAE ran low on memory, etc." when opening a session with Channelstrip instantiated in Pro Tools 5.0.1. Chris
Hey Chris, just to make sure about installers and installed plugins versions, here's what I used:
- Access Indigo installer (AccessIndigo7_21532.dmg, downloaded from Digi site), which opens in the 'Install Access Music Indigo' version 8.2, which installs the plugin 'Access Music Indigo.dpm' version 7.0 - SoundToys UltraTools|HD OSX 2.4.5 (downloaded from SoundToys site) version 8.4 which installs (in a 'SoundToys' folder within the plugins folder) 'PitchBlender|HD 1.5.4' and 'TimeBlender|HD 1.5.4' Are these the same that you have ? Thanks !
Hi Steve, Yes same version! the latest and greatest from both access and soundtoys, and soundtoys has its own folder inside the plugins folder, same as you!! Clean un-install of PT and reinstall is the only option to be sure you have all the right stuff in the right places! It does seem strange if other plugins are working ok? and only these two are giving you problems! But i can guarantee you there are plenty of users with both these plugs working ok. Both indigo and pitch/timeblender are both TDM!? so only thing i can suggest is looking at your DSP-voices etc! try more DSP for less voices? 4 DSP 96 voices, if you haven't allready tried this!? But fresh install should fix, if it does not fix, then it sounds like you have some anomoly with your system! Chris
Avid Access Virus Indigo? | timeey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-02-2012 04:09 AM |
Access Virus Indigo AAX? | stargazer | macOS | 2 | 11-30-2011 03:32 AM |
Access Virus Indigo | James Drake | Pro Tools TDM Systems (Mac) | 4 | 06-23-2010 02:20 PM |
PT 6.4.1 Mix & Access Virus..? (Red or Indigo) | Citrin | Pro Tools TDM Systems (Mac) | 2 | 03-03-2009 07:00 PM |
Access Virus Indigo Problem | PedMar | Pro Tools TDM Systems (Win) | 5 | 06-18-2004 03:55 PM |
