Pro Tools 2023.3 with Mojave 10.14.6 Issues
Is anybody running ProTools 2023.3 with Mac Mojave 10.14.6? If so, are there any issues you have noticed? Does it work correctly? ARA working?
I searched the DUC but found no entries for these questions.Thanks.
ProTools 2021.12, Lynx Aurora (n) 32 TB, Sibelius 23.2.0; OSX 10.14.6; Mac Mini: 3.2 GHz Intel Core i7; 64 GB 2667 MHz DDR4; Internal 2 TB SSD, External Sabrent TB 2 TB SSD Also ProTools 2021.12, 002R,; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 128 GB 1333 MHz DDR3 ECC; Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G 2 TB SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB |
Re: Pro Tools 2023.3 with Mojave 10.14.6 Issues
Best. G https://avid.secure.force.com/pkb/ar...m-Requirements
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
You can have multiple versions of pro tools installed now. While 10.14.6 isn't officially supported or tested, AVID says you should be able to use it. So go ahead and install it and test it. Just make sure to rename your current version.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card. OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW. Almost every plugin |
I have been running Pro Tools 2023.3 for several months now on Mojave. The only issue that I have run across is that under ignore Errors During Playback/Record, if I have "Minimize Additional I/O Latency" selected, the session keeps stalling and suggest a CPU Overload. Once unchecked, this problem went away.
Anyone tried 2023.9 on Mojave?
It's worth switching to Monterey. I used PT 2022/23 on Mojave on Cheesegrater 5,1 for a long time and the things that bothered me with Mojave are working with Monterey. The performance is similar, but for example the windows handling is so much better - i use 3 monitors, and PT now remembers positions of all the windows when saving the session. Much better. I highly recommend leaving Mojave behind.
__________________________________ cMP 2 x 3,46, 128GB Ram Monterey 12.7.4 Metric Halo 3d 2882 I/O Lucid 88192 with Blue Sky 5.1 monitoring 10gbE ethernet with True Nas storage |
Hi.
I’m glad I found this post. I updated to 2023.3 from 2022.9 and had nothing but problems. Beachballs, CPU errors and crashes. I thought it might be plug ins, changed buffer sizes. Checked and unchecked every box. Took screen shots of everything. New sessions would stall before I even added tracks. The 4th Core was always at 100% in every case. All the other cores were up over 50% with no audio. No tracks added. Just open. I thought it might be the Apple DVI Cinema Display that I was using. In the end I went back to a clone HD which had 2022.9 installed pre the update. Every single problem went away. 2023.3 is not for Mojave I can tell you that. After I clone this drive again, I’ll go back to the 2023.3 drive and update it to 2023.9 and let you know. Probably next week. … yes, I need to update my signature info. Currently running Mac OSX Mojave 10.14.6 & Pro Tools 2022.9 with an HD Native card.
AQ. Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6 Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9 Black Lion modified OMNI HD w/XB clock Multiple Black Lion modified 192 FM/XB interfaces Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native) |
Thanks.
Anyone using Catalina with PT 2023.6? I've finally gotten to a place where things are working with PT 2023.6 using the 2023.3 HD Driver. I'm still testing but using the same session and going back a forth between 2022.9 & 2023.6 everything seems to be working as it should. Now it's testing the plugins time. I just got the UAD plugins working with a firmware update. Softtube, Sonnox, SoundToys, TC, Waves are all working. I'm working my way up the manufacturer's list.
2023.3 Aux IO/Dolby Audio Bridge Issues | MPizzaMusic | Pro Tools | 2 | 12-19-2023 08:39 AM |
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! | off the wall | Pro Tools | 9 | 03-28-2023 10:33 AM |
Protools 2020 intersystem issues between mojave and catalina | Elisundermann | Pro Tools 2020 | 3 | 01-24-2022 06:12 AM |
Anyone having issues with Security Update 2021-002 (Mojave) and PT 2020.12? | Cacov | Pro Tools 2020 | 3 | 02-28-2021 04:22 AM |
GUI issues - 2019.5 and Mojave | BrandonUnis | Pro Tools 2019 | 12 | 06-21-2019 08:42 PM |
