Old 09-02-2015, 01:00 PM
vieris vieris is offline
Default PD-1 lag/punch problems with 11/12.x
I’ve been troubleshooting a PD-1 issue the last few days. I’m out of ideas, & curious if any of you had any insight.
With PT11-12.1HD we get inconsistent punches (audio flamming), & a lag when coming out of record via the PD-1 paddles. With PT10 this is not the case, it is near sample accurate.
I originally thought this was the Low Latency USB422 driver with mavericks/yosemite issue, I rolled back to OS 10.8.5 so I could test with the standard non-patched driver & install PT10HD to compare.
PT12 on OS 10.8.5 is also showing the problem so that rules out the driver.
All SyncHD's are clocked to a common wordclock & receiving video ref. I’ve tried different clock scenarios (Video vs Word) no difference. I’ve confirmed that both PT10 & 12 9-pin prefs match, I can’t think of any PD-1 menu options that might help.
Is this just an problem with PT post ver 10?
"Any experiment of interest in life will be carried out at your own expense."
Old 09-02-2015, 04:35 PM
DJ Insomaniac DJ Insomaniac is offline
Default Re: PD-1 lag/punch problems with 11/12.x
Is delay comp on, and are you cascading recording tracks?
Sam Ejnes
Re-recording Mixer
samejnes.com | IMDb | Analog Jitter
Old 09-02-2015, 05:02 PM
Nope, compensation is off/no cascading. It's a punch accuracy issue with 11/12 only.
Here is an image from a test punch. You can see the in/out point error. It's an odd one, PT10 same hardware no issue.
https://flic.kr/p/y8w8bs
Old 09-02-2015, 05:07 PM
PT 12 is fine if you manually punch in with the surface/mouse it's only via the PD-1.
Old 09-02-2015, 09:27 PM
Postman Postman is offline
Vieris,
With respect, what you show is not a "punch accuracy" but rather is a "positional accuracy" problem. Are your certain the problem happens ONLY when punching via PD-1? Is the source audio coming from exactly the same system in both cases? In other words, are you changing only the record system from 10 to 11/12, with NO OTHER CHANGE? Are you using LTC as positional reference? I am wondering if PT 11/12 is not locking up with the same precision as PT10, but there are variables that are unknown (to me).
Old 09-02-2015, 11:42 PM
Originally Posted by Postman View Post
Vieris,
You are correct it is a "positional accuracy" problem. PT10 is the only change.
The setup is as follows.
  • Four systems total.
  • Two source rigs running PT12HD (HDX3, & HD Native)
  • The recorder in question (HD Native) Running PTHD 10/11/12, & the PD-1
  • Video playback system.
  • All are satellite linked.
  • All have house wordclock, video ref, & LTC set for positional ref.
  • I/O interconnect is MADI.
It would be great if someone could recreate this following simple test.
  • From two systems connected via satellite link, record tone from the source system into a recorder with the PD-1.
  • Make a PD-1 punch with the same source audio content & confirm "positional accuracy".
  • Compare PT 11/12 vs 10.
HTML code is On
Quick punch.... can't hear track audio until I punch in stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-31-2017 02:11 AM
Quick Punch problems Larry Crane Pro Tools TDM Systems (Mac) 4 02-20-2011 11:55 AM
quick punch problems ukuleles1212 Pro Tools M-Powered (Win) 1 11-25-2009 03:50 PM
Record punch in problems jefflennan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-10-2009 07:20 AM
Help! Problems with punch record mode Cosme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-27-2004 06:06 AM
