Is there a way to sync the Midi Editor and the Edit Window
Is there a way to sync the Midi Editor and the Edit Window(Audio) where they move together?
Case in point, if I’m not playing with a click and my keyboard playing sucks…which it does and I want to edit the midi by eyeing it(and listening of course) to match the audio regions….is there an easy way to do this, a way to lock the two. As it is now…I have to rig the two windows to be near each other…move the midi file around and go back and forth zooming the audio & midi and on & on. Thanks! |
Re: Is there a way to sync the Midi Editor and the Edit Window
Just in case my description sucked, I'm not trying to get the midi to lock to audio...just visually be able to follow the midi edit window & the audio edit window together...synced
Upper right hand corner of the midi edit window--look for the triangle.
Drop-down menu has a sub-menu "scrolling", one option is "follow edit window" Maybe a little tricky if they're not set to the same zoom amount, I can't remember. But you'll get a feel for it.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
I would change the midi/instrument track to 'note' view in the edit window and make the track size as big as you need. Also zoom in on the midi notes (near the regular zoom buttons at the top of the edit window) so you can see the notes better. You can follow along right below the audio track.
There is also a way to view the midi window split at the bottom of the edit window but I find doing right on the track much better. |
Make MIDI editor track selection independent of edit window? | tooold | Pro Tools 11 | 3 | 01-30-2015 10:34 AM |
Linking Midi Editor With Edit Window | ROCKYIII | Pro Tools 10 | 0 | 05-26-2014 01:02 PM |
Opening MIDI editor at current Edit window position | tooold | macOS | 0 | 01-08-2014 09:40 AM |
How to: Switch between sub-windows: Midi editor inside of edit window | bashville | macOS | 3 | 10-20-2012 07:59 PM |
How do I link Edit Window & Midi Editor? | Lukehanigan | MIDI | 2 | 12-02-2009 05:40 PM |
