Old 04-21-2013, 11:06 PM
Reatsch Reatsch is offline
Default TDM Plugin not Found, -7 Error Message
Hello gusys, i run Pt 10 on a Windows 64 bit system and since the first day i keep having trouble with PT.
I am working on several project that keep screwing up during the mixing process.
how can i figure out what i need to do? since almost every session i keep having BIG problems...alot of times even a bluecreen.
is there a chance to find out what this is about?
greetz
reatsch
Old 04-22-2013, 08:13 AM
Default Re: TDM Plugin not Found, -7 Error Message
How can anybody help you when we know absolutely NOTHING about your setup? Help us Help You - READ THIS Before Posting!
Old 04-25-2013, 12:58 PM
thnx dave...but this does not bring me any further...i have like no clue about what this says...i can read and talk english but i aint that good into it...
Old 04-25-2013, 01:18 PM
You need to post a Sandra report and give details about ALL the hardware that's connected to your computer. Without that, nobody has a prayer of helping
Old 04-26-2013, 03:15 AM
ok ...thnx alot for the information..i am going to do that during the next days!
Old 05-20-2013, 11:42 AM
So Hey there,
i have my sandra report right underneath:
SiSoftware Sandra
Nr
Hostname : Reatsch-PC
Arbeitsgruppe : WORKGROUP
System
Modell : OEM System Product Name
Serialnummer : System Ser**********
Gehäuse : Desktop
Mainboard : ASUS P8Z77-V LX
Serialnummer : MT70250********
System BIOS : AMI (OEM) 0610 05/08/2012
Gesamtspeicher : 16GB DIMM DDR3
Prozessor(en)
Prozessor : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (4C 8T 3.91GHz, 3.9GHz IMC, 4x 256kB L2, 8MB L3)
Sockel/Slot : FC LGA1155
Chipsatz
Speichercontroller : ASUS Core (Ivy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.33GHz 128-bit
Speichermodul(e)
Speichermodul : TakeMS TMS4GB364E081139EM 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5)
Grafiksystem
Monitor : ACR G195HQV
(1600x1200, 18.5")
Monitor : FUS SL3230T
(1920x1080, 23.0")
Grafikkarte : ATI Radeon HD 3600 Series (120SP SM4.1 725MHz/600MHz 20% OC, 512MB DDR2 1GHz 128-bit, PCIe 2.00 x16)
Grafikprozessor
Physische Speichergeräte
Seagate ST31500541AS (1.5TB, SATA300, 3.5", 5900rpm) : 1TB (J:)
SAMSUNG HD103SI (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (D:)
Samsung SSD 840 Series (250GB, SATA600, SSD) : 233GB (C:)
Generic- Compact Flash (USB2) : k.A. (F:)
Generic- SM/xD-Picture (USB2) : k.A. (G:)
Generic- SD/MMC (USB2) : k.A. (H:)
Generic- MS/MS-Pro (USB2) : k.A. (I:)
HL-DT-ST BDDVDRW CH10N (SATA150, BD-R, DVD+-RW, CD-RW, 4MB Cache) : k.A. (E:)
Logischer Speichergeräte
System-reserviert : 100MB (NTFS)
Daten (D:) : 932GB (NTFS) @ SAMSUNG HD103SI (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
Festplatte (C:) : 233GB (NTFS) @ Samsung SSD 840 Series (250GB, SATA600, SSD)
Volume (J:) : 1TB (NTFS) @ Seagate ST31500541AS (1.5TB, SATA300, 3.5", 5900rpm)
Auswechselbares Laufwerk (F:) : k.A. @ Generic- Compact Flash (USB2)
Auswechselbares Laufwerk (G:) : k.A. @ Generic- SM/xD-Picture (USB2)
Auswechselbares Laufwerk (H:) : k.A. @ Generic- SD/MMC (USB2)
Auswechselbares Laufwerk (I:) : k.A. @ Generic- MS/MS-Pro (USB2)
CD-ROM/DVD (E:) : k.A. @ HL-DT-ST BDDVDRW CH10N (SATA150, BD-R, DVD+-RW, CD-RW, 4MB Cache)
Peripherie
LPC Hub Controller 1 : ASUS Panther Point LPC Controller
LPC Legacy Controller 1 : T0 C5-62
Audio Gerät : ASUS RV635 Audio device [Radeon HD 3600 Series]
Audio Codec : ATI (AMD) HDMI Audio
Audio Gerät : 6656 Universal Audio UAD-2 Solo
Serielle Port(s) : 1
Laufwerkscontroller : ASUS Panther Point 6 port SATA AHCI Controller
USB Controller 1 : ASUS Panther Point USB xHCI Host Controller
USB Controller 2 : ASUS Panther Point USB Enhanced Host Controller #2
USB Controller 3 : ASUS Panther Point USB Enhanced Host Controller #1
FireWire/1394 Controller 1 : TI TSB12LV26 OHCI Compliant FireWire Controller
System SMBus Controller 1 : Intel ICH SMBus
Drucker- und Faxgeräte
Drucker : Microsoft XPS Document Writer (600x600, Farbwiedergabe)
Peripherie
Netzwerkdienste
Netzwerkadapter : Realtek PCIe GBE Family Controller (Ethernet)
Drahtlosadapter : Atheros AR7015 Wireless Network Adapter (802.11n (HT), AES-CCMP, 300Mbps)
Betriebssystem
Windowssystem : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Kompatibel mit Plattform : x64
Windows Leistungsindex
Aktuelles System : 5.2
Old 05-20-2013, 11:50 AM
and here is a error message or better knwon as bluescreen message that appears:
usually i open up a project, in this case it doesnt matter if i open pt 10 and than load the project i am working on or just load the project itself that i named like "song 1".
when pt starts i become the error: -7 ; i click on ok and than it tells me the tdm plugin hasnt been found.
so good so far...
sometimes i can work on this project for like 10 minutes or more but than just without a warning my pc crashes and the blue screen shows up.
even when i am loading the project crash files it happens again and again and again...
Old 05-20-2013, 11:57 AM
i am using a usb (no cable) keyboard and mouse from Logitech.
i have a ilok2 attached
NI maschine is also conencted via usb (front port)
firwire is connected only to my mbox pro there is no more fw (everything is up to date)
i have a onboard dsp card from uad, the solo which is up to date and running just fine
Old 05-20-2013, 08:08 PM
Sorry I can't help. I have no experience with Mbox Pro or UAD cards. That 5900 rpm drive, should NOT be used for sessions. Wifi should be disabled when running Pro Tools(at least until things start working). I would open device manager(with internet connected) and go thru everything updating drives(BSOD can be an outdated driver). The message re. TDM plugin is a head scratcher as you cannot run TDM plugins. Maybe you installed the TDM version of something? If so, uninstall and reinstall, choosing the RTAS version.
Old 05-20-2013, 08:25 PM
The bluescreen may or may not be directly related to your other problems.
I would start with a files system check of every hard drive.
Get an up to date anti-virus software and scan the entire computer. wdf01000.sys (WDF== Windows Driver Framework runtime) is sometimes attacked by malware. Then fully disable/turn off the antivirus software (it should never be running when you are actually using Pro Tools).
Try updating all windows software, especially all drivers for your hardware -- from Microsoft Update and directly from OEMs.
If that does not help with the blue screens try wiping the system and reinstall Windows. Try to add as few third party drivers/software etc. as absolutely needed and see what works.
Darryl
Melodyne Plugin ERROR (MPView Not Found) Win XP Protools LE 8.0.3 CORFA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 07-17-2010 09:43 PM
Entry Point Not Found - error message DjA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-06-2007 11:34 AM
HELP! error message - "entry point not found" leonardrock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-29-2006 06:47 PM
dae.dll not found message wnsmd Digidesign Hardware & Software 0 01-20-2001 02:12 AM
Card not Found Message rope777 Digidesign Hardware & Software 1 06-15-2000 11:38 AM
