How to: Switch between sub-windows: Midi editor inside of edit window
Problem--I have the midi editor open as a sub-window beneath the regular edit window. You can see one is highlighted with a yellow boundary around the top of the "active" section. I like to work with both the full track regions visible above, and work with the midi contents underneath. If you use the function keys to switch tools, it switches the tool in the highlighted window.
So I've dug around in the reference guide and online, and I wasn't sure how to search for this. Is there a shortcut to change the focus between the upper and lower sub-window? Right now, the only way I know how to do it is to click on the section I want. That method is becoming annoying, and I'm wishing I could find a key command for it. Does anybody know how to do this? Thanks for any response--Kevin
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Re: How to: Switch between sub-windows: Midi editor inside of edit window
bump--
does anybody else work this way?
From Edit window to MIDI Editor = Option-Command-4
From MIDI Editor to Edit window = Option-Command-5 |
That was it! "Toolbar Focus" in the manual. Thank you Joe!
Opening MIDI editor at current Edit window position | tooold | macOS | 0 | 01-08-2014 09:40 AM |
Can you trim MIDI regions from inside the MIDI editor window? | emspace | Pro Tools M-Powered (Mac) | 0 | 07-06-2010 12:13 PM |
How do I link Edit Window & Midi Editor? | Lukehanigan | MIDI | 2 | 12-02-2009 05:40 PM |
Shortkey command for mix/edit window switch | meltra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-06-2009 01:10 PM |
how to put transport window inside edit window? | keithl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-18-2004 06:47 PM |
