Firmware in 002 rack not updating
I have a generic FireWire card and the software gets to about 90% on updating the firmware on the rack unit and quits without completing the update. I talked to tech support and they suggested one of the cards listed here, however it only refers to the Mbox and external drives and not the 002 rack.
I've done all the system tweaks and performance settings that Digidesign recommends and even went further and did some special system settings like disabling DEP. Before I go purchase another FireWire card can someone tell me if this would definitely solve the problem? Or, could there be another cause? Digidesign recommended FireWire/1394 Controller PCI Cards: * ADS PYRO PCI 64R2 Part Numbers: o API-315 (RoHS compliant) o API-311 (discontinued) Bus type: 64-bit PCI * SIIG 1394 3-port PCI i/e Part Numbers: o NN-440012-S8 (RoHS compliant) o NN-440012 (discontinued) Bus type: 32-bit PCI My system spec's: Windows XP Professional, Sv Pk 2 ASUS P4P800SE, Intel 865PE Northbridge and Southbridge Intel 3.0GH Processor 1 GB Ram 7200 RPM IDE drives configured at 32bit System is configured for recording and audio editing only |
Re: Firmware in 002 rack not updating
The answer depends on what the present firewire controller is. If its a TI chip, then it SHOULD work, but if it not a TI, then getting an approved firewire card is mandatory for using the 002(and hopefully would cure the firmware update problem as well). Keep in mind that those firmware updates sometimes need to be run a few times before it actually succeeds.
Are you saying that the chip set on the firewire card needs to be a TI (Texas Instruments) chip? I don't think it is or at least I don't see that anywhere on the box in the spec's. I've already tried multiple times to do the update but no joy.
Yes, it should be a TI chip set. If you follow this link
Compatibility & Upgrades you can find some approved firewire cards.
Thanks, I've already read most of that. I'll pick up one of their recommended cards.
How important is it for the firmware to match the version of Pro Tools? It works fine from what I've been able to observe. |
OK, this is incredibly ridiculous. I bought one of the recommended (ADS Tech) Firewire cards with the TI chipset and it still won't update the firmware. I'm using one of the highest quality shielded firewire cables, I set up all the windows configurations and have conformed to everything the Digidesign tech support people require and it still won't update.
Is there a way force this thing to accept the firmware update? Is there something wrong with LE v7.1? Is there a reason to update it anyhow? This is really driving me nuts now. I've sat here all afternoon restarting Pro Tools to update. Probably over a dozen times now. |
What happens if you cancel the firmware update?(or click LATER" or whatever the other option is as I can't remember). It may well work just fine(a little finger crossing won't hurt). I'm at a loss as to why its not working for you. The worst I ever had was once when it took 3 attempts to go thru(I can't remember which version). As for upgrading, PT8 gives you Elastic Audio, Elastic Pitch, MiniGrand, DB-33 and a bunch of AIR plugins and is well worth it(to me anyway). Be forewarned that some 3rd party plugins would need updating(all my Waves plugs needed it).
Well that's the $1000 question I guess. Will it work fine without updating. I've used Pro Tools and other multi-track programs before so I know when they're not working correctly. I guess I'll just have to take a wait and see approach. This is really frustrating though since I've taken all the steps to solve it but nothing has worked so far.
The firmware on the rack unit is v.1.08 and the software wants to update it to v.1.21. I assume that Digidesign made some important changes to the way the recording software communicates with the rack unit but I just don't know. Is there any way to find out and see it it's critical or just an annoyance? |
Updating firmware | time_ghost | Pro Tools HDX & HD Native Systems (Mac) | 4 | 12-30-2013 02:04 AM |
003 rack firmware not updating..urgent help pleassssss | sguy006 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-01-2009 12:55 AM |
Updating 003 Rack System Firmware - Long?? | KingFish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-10-2009 06:48 AM |
Firmware not updating | cjbeckius | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-15-2006 11:47 PM |
firmware updating | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 05-19-2004 03:01 AM |
