Old 08-02-2021, 08:35 PM
Top Jimmy's Avatar
Default Re: Pro Tools requires the DSP mixer plugin in the plugins folder!!!!!!
Originally Posted by MFred View Post
Hi !
I have the exact same issue and I've done everything you said
( Clean Reinstall, Launch Protools pressing the "N" key and choose " HDX" playback engine, even reinstall Moutain Lion + Protools on another drive )
Nothing works !!!
Protools is still asking for this DSP Mixer Plug and close...
IDK what to do
If anyone has an idea ?
Thx
Pro Tools used to install all 4 versions of the mixer with the ones not used in the unused plugins folder. Check the unused plugins folder and if they’re all there, move the one you want to the plugins folder.
Macintosh HD > Library > Application Support > Digidesign > Plug-Ins (RTAS & TDM)
Macintosh HD > Library > Application Support > Avid > Audio > Plug-Ins (AAX)
James Cadwallader
Old 08-03-2021, 01:06 AM
MFred MFred is offline
Hi James ! Thank you for your reply
I’ve already moved the Stereomixer.dpm from the unused plug-ins folder to the plug-in folder in the Digidesign Application support
The Mixer.aax was already in the plug-ins folder in the Avid Application support.
It still doesn’t work and Protools still requires the DSP mixer plug-in...
I have to mention that when the mixer.aax and the stereomixer.dpm are in their plug-in folders, I also have a dae error -13811
It is very strange because I’ve never experienced this issue before and everything was working perfectly a few days ago
Old 08-03-2021, 01:30 AM
JFreak's Avatar
JFreak JFreak is online now
Hi, welcome to the community.
First make sure your setup is a supported configuration, then delete everything from the plugins folder and install again. After installation, confirm that you have the mixer plugin in there (that is the HDX mixer) and relaunch PT.
Janne
Old 10-23-2021, 07:48 AM
chriscasswillmakeyoujump chriscasswillmakeyoujump is offline
Hi MFred,
Did you ever figure this out?
I am also getting this, I have tried everything I can read on the subject installed/uninstalled, installed new OS, moved the plugin into the folder, Did the start up N & tried various versionsof PT still nothing.....
Help! Pro Tools won't start Pro Tools with TDM requires the TDM mixer plug-in in plug Winterland Pro Tools TDM Systems (Mac) 9 08-12-2009 12:42 PM
Message "Pro tools with tdm requires the tdm mixer plug-in in the plugins folder" Alexei Zaitsev Pro Tools TDM Systems (Win) 0 01-10-2009 03:48 AM
UAD TDM PLUGINS NOT FOUND IN PLUGIN FOLDER heromusic Pro Tools TDM Systems (Mac) 1 03-13-2008 02:24 AM
plugins in my folder but not in pro tools musiceng711 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-12-2007 09:20 PM
6.7 requires TDM mixer Plug-in??? Glenn75 Pro Tools TDM Systems (Mac) 3 11-05-2004 10:24 PM
