HELP! DAE -9060 -9031 errors(sandra)
I never had these errors come up before which is really weird right now. This seems to happen whenever I edit a track or add a fade. Please help this is messing up my work flow. I have tried trashing my preferences and reinstalling still no go.
SiSoftware Sandra Computer Model : HP HP Pavilion dv7 Notebook PC Workgroup : WORKGROUP Host Name : DIGIT-LAPTOP User : Ramon Processor Model : Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20GHz Speed : 2.2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel Centrino Duo Mobile Technology Mainboard : HP 3624 BIOS : HP F.41 11/12/2009 Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DDR3 SO-DIMM Chipset Model : HP PM45 Mobile Controller Hub Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 4GB DDR3 SO-DIMM Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Samsung M471B5673EH1-CH9 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Samsung M471B5673EH1-CH9 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Mobility Radeon HD 4650 (SM4.1, 1GB DDR3, PCIe 2.00 x16) Graphics Processor Adapter : ATI Mobility Radeon HD 4650 () Storage Devices ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (D:) WDC WD10EADS-00L5B1 (1TB, SATA300, 3.5", NCQ, 32MB Cache) : 932GB (F:) (H:) (N:) hp BDDVDRW CT10L (SATA150, BD-R, DVD+-RW, CD-RW, 4MB Cache) : N/A (E:) Logical Storage Devices SYSTEM : 199MB (NTFS) Windows7 (N:) : 59GB (NTFS) @ WDC WD10EADS-00L5B1 (1TB, SATA300, 3.5", NCQ, 32MB Cache) DIGIT MUSIC (F:) : 422GB (NTFS) @ WDC WD10EADS-00L5B1 (1TB, SATA300, 3.5", NCQ, 32MB Cache) DIGIT DATA (H:) : 422GB (NTFS) @ WDC WD10EADS-00L5B1 (1TB, SATA300, 3.5", NCQ, 32MB Cache) Hard Disk (C:) : 425GB (NTFS) @ ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) RECOVERY (D:) : 15GB (NTFS) @ ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) Optical Drive (E:) : N/A @ hp BDDVDRW CT10L (SATA150, BD-R, DVD+-RW, CD-RW, 4MB Cache) Peripherals LPC Hub Controller 1 : HP (ICH9M) LPC Interface Controller Audio Device : HP (ICH9) HD Audio Controller Audio Codec : Integrated Device Tech 7603h Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) HDA softmodem Audio Device : HP RV730XT Audio device [Radeon HD 4670] Audio Codec : ATI (AMD) AA01h Serial Port(s) : 3 Disk Controller : HP (ICH9) Mobile SATA AHCI Controller USB Controller 1 : HP (ICH9) USB Universal Host Controller USB Controller 2 : HP (ICH9) USB Universal Host Controller USB Controller 3 : HP (ICH9) USB2 Enhanced Host Controller USB Controller 4 : HP (ICH9) USB Universal Host Controller USB Controller 5 : HP (ICH9) USB Universal Host Controller USB Controller 6 : HP (ICH9) USB Universal Host Controller USB Controller 7 : HP (ICH9) USB Universal Host Controller USB Controller 8 : HP (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : HP IEEE 1394 Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Officejet 6500 E709a Series (600x600, Colour) Printer : HP Officejet 6500 E709a Series (1200x1200, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller Network Adapter : Anchorfree HSS Adapter Network Adapter : VirtualBox Host-Only Ethernet Adapter (Ethernet, 100Mbps) Network Adapter : TAP-Win32 Adapter V9 Wireless Adapter 1 : Intel(R) WiFi Link 5100 AGN (802.11g (ERP), AES-CCMP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.7 Anyone can help me out here?
Ramon -- site: http://www.everythinglegit.com Wah gwaan down deh.. System: Pro Tools LE, mbox 2, m-audio keyboard, HP DV7 laptop, Reaper 3 and alot of studios. |
Re: HELP! DAE -9060 -9031 errors(sandra)
That's indeed strange.
What comes to my mind is: - check whether your audio hard disk is fragmented if yes, copy your sessions to a safe place format the drive and copy back - otherwise try the usual things, disable network and internal audio and possibly check your interface connections USB or Firewire
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Do you have virus protection enabled? Do you possibly have compression enabled for the audio files used in the session, or to the folder where your fade files are being written? Do you possibly have illegal characters in the drive, folder or files names for anything used in the session?
try trashing your prefs.
Sorry for the late reply, had a busy week.
Tried it the first time. Same thing. Even tried disabling all plug ins.
Otherwise I would re-install PT.
Well just did a check, the hard drive is fine and works perfectly on my desktop. Already tried the reinstall.
Ramon, do you not have a system drive clone or image that you can refer to? Usually that will cure all evils.
its 3 months old...haven't gotten my system stable enough to clone again.
Every session I open I keep getting this error when I do a create a fade on a track and sometimes it keeps looping the errors..its really annoying no one have any way to fix it? and what does the error suggest? I'm on tour so you must understand how crucial this is to me.
PPC G Drive - DAE Errors 9060 9031 9060 on playback | qwertyuiop | Pro Tools TDM Systems (Mac) | 8 | 09-18-2015 02:09 PM |
HELP!!! DAE ERROR 9031 AND 9060 errors! | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 02-23-2011 06:44 AM |
DAE Errors 9060, 9031, and 9073 | AldenWitt | Pro Tools M-Powered (Win) | 0 | 02-10-2011 08:37 PM |
9060 and 9031 dae errors after upgr to 8.0.3 | breakie | Pro Tools TDM Systems (Win) | 28 | 07-05-2010 11:18 AM |
-9060 & -9031 errors. | duffy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-23-2010 01:10 PM |
