Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 07-11-2021, 04:58 PM
digiot digiot is offline
Default Re: 2 Dongles for Ethernet!?
Originally Posted by K Roche View Post
Sorry to be so dense but I still don't understand. The double dongle only has to do with going from Carbon to Macbook pro. But If your Macbook Pro has a second TB 3 port ?? Can't you connect the Samsung to the Mac via TB 3 and then have two displays , the Macbook and the Samsung ?
I have plenty of Thunderbolt 3 ports. But there is no Thunderbolt 3 to Ethernet adapter so therefor I still need 2 dongles!
Old 07-12-2021, 05:23 AM
K Roche's Avatar
K Roche K Roche is offline
To run the Carbon yes, BUT not to run the Samsung display in your system.
I am guessing we are talking about two different things .
I am guessing what you actually meant in your OP was you were trying to use Your Samsung Display as an ethernet hub ? and connect the Carbon to it and then from it to your Mac (which does not work) yes ??
And Yes I understand you need 2 dongles to connect the Carbon to the Mac ... BUT My point was that in order to run the second display in your system , you don't need to connect the Samsung to the Carbon , you can simply use a TB3 connection to go straight from the Samsung to the Mac. And then it will work as a second display
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 07-18-2021, 08:21 AM
Yeah my OP was solely based on the fact that I need 2 Thunderbolt dongles to run the carbon. I have no problems connecting my 4K Display. As a matter of fact the 4K display connects 2 UAD devices over Thunderbolt 3, an Avid Artist Mix over ethernet and all my USB3 devices, plus it charges the MBP. So all in all I only use 2 Thunderbolt3 ports on my MBP to connect everything!
Old 07-19-2021, 06:22 AM
K Roche's Avatar
What remains to seen is what the second AVB port on Carbon will be used for My Guess is some kind of Avid hardware I/O box???????????
System :
Enjoy the Journey
.... Kev...
Old 07-19-2021, 01:11 PM
I actually experimented with that second Ethernet port and I was able to get it to see my Avid Artist Mix and use it for wired internet!
Dongles and DOD johnnyu Pro Tools 10 26 12-12-2012 04:02 PM
Dongles Shrackattack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-09-2009 06:55 AM
Dongles Dongles Everywhere Digibill Pro Tools TDM Systems (Mac) 21 02-10-2006 04:58 PM
Dongles/usb john a Pro Tools TDM Systems (Mac) 3 01-15-2002 10:07 AM
New G4 w. Dongles Charles Deenen Tips & Tricks 1 12-18-1999 03:49 PM
