Old 02-07-2024, 03:09 AM
oortone oortone is offline
Default Bouncing stems produced clicks/pops in Main
I made a bounce like this (see figure) and the Main stem file got clicks/pops. These were not coinciding with high peaks near fullscale but way below. All other stems in the project are subgroups routed to Main. No pops in these.
If I bounced only Main, no pops/clicks.
Repeated several times with same result.
Has anyone seen anything similar?
Old 02-07-2024, 04:46 AM
tope d's Avatar
tope d tope d is offline
Default Re: Bouncing stems produced clicks/pops in Main
Have you tried importing this sessions data to a new session to see if the same issue occurs?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
tope d's Avatar
-Tope
www.topedomingo.com
Old 02-07-2024, 05:26 AM
its2loud its2loud is offline
If MAIN is your physical hardware outputs, don’t bounce this way. Use an internal bus as your source to bounce the full mix.
Old 02-14-2024, 05:26 AM
Yes, I suspected that could be the issue. Do you know why that is?
What does it actually mean to bounce the "physical output" vs. the "main bus" (that goes to the physical output). I mean, the actual physical output is of course not really acessible for ProTools from within ProTools, it would have to be routed manually back into some input.
Clicks and Pops when bouncing files spida 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2008 09:34 AM
Clicks/Pops Randomly when Bouncing To Disk Robearto4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-25-2008 10:05 AM
Pops. Clicks, and Distortion When Bouncing alfadog Pro Tools M-Powered (Win) 3 12-23-2006 04:53 PM
Pops and clicks when Bouncing to Disc! acacia Pro Tools TDM Systems (Mac) 20 09-15-2005 03:53 PM
Clicks & pops bouncing in 5.01/Magma/TiBook Craig Woolard Pro Tools TDM Systems (Mac) 5 02-08-2002 10:20 AM
