Old 09-09-2016, 05:07 AM
Mark Ziebarth Mark Ziebarth is offline
Default Kernel Panic
I'm having a strange problem on my main system. Some sessions cause kernel panic if I try to load them. Typically these are bigger sessions with 50 plus tracks and a lot of plugs. The panic happens when PT tries to load the plugs.
I checked my HD cards with DigiTest but everything's okay. I trashed all preferences but it happens again.
The funny thing is that I can open the sessions on my PT 12 system without a problem. If I open them there and save the session with a new name I can open it on my main system but only once. If I save on the main system and try to open again the kernel panic happens again.
It's happening with four or five completely different sessions.
Any ideas?
Best
Mark
Gesendet von iPad mit Tapatalk
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 09-14-2016, 04:22 AM
Default Re: Kernel Panic
Anyone?
Old 09-14-2016, 07:35 AM
dtmprod dtmprod is offline
Hi;
Don't know if this will help, but I've discovered that some of the newer versions of AAX plugins don't play well with PTHD 10. One of the worst seems to be Slate's VMR, I've totally given up on that & am back to using VCC 1. Overall, dpm versions seem to be more stable than AAX, so I've pulled the AAX whenever the older dpm is duplicated.
If there are newer AAX plugins that seem to be necessary to use, try instantiating them first in a small minimal session. Then they seem to work in the larger session. I've been doing that with Eiosis de-esser, Oxford Envolution & Sound Radix Surfer EQ 2. Have no idea why. But these days, I always keep the older versions when updating plugins. That way if the new one doesn't seem to work, I can quickly revert back to the older working model. So that might be something to investigate. If the manufacturer doesn't post 'legacy installers', request & try earlier versions to see if that helps.
Hope that helps.....
Old 09-17-2016, 10:38 AM
Question Re: Kernel Panic
Which release of v10? v10.3.10? Are you using the DSP cache with v10?
Old 09-18-2016, 01:37 AM
I'll check the version tomorrow. I've been using DSP cache but turned it off last Friday. Maybe that helps. But the crashes even happen when I start the computer in the morning and open one of the critical sessions as the first one.
Best
Mark
Old 09-19-2016, 01:25 AM
tonwurm's Avatar
tonwurm tonwurm is offline
I don´t believe that the hangs are related to dsp-cache. You are stating that these are bigger sessions that cause the issue, so maybe it´s a RAM related thing (exactly what I had some years ago - faulty RAM chip). Or one of your accel cards has an error (had that too). digitest isn´t such reliable ... at least my experience.
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 09-19-2016, 04:56 PM
Do you have access to Pro Tools v9.x on the same hardware (computer, cards), and if so, do those sessions open up in v9.x without a problem?
Old 09-21-2016, 07:53 AM
I just found the time to try again today, and it's as simple as that: Without DSPcache everything seems to work fine. I tried three of the critical sessions and they opened without a problem.
Thanks for your help.
Best
Mark
Old 09-21-2016, 09:51 AM
tonwurm's Avatar
hervorragend ;-)
Ultimate HDX
Old 09-21-2016, 01:00 PM
Well, I'm glad it's not a RAM issue on the Motorola boards...or anything special at all.
Heiter weiter
Mark
Kernel Panic Bray90820 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-29-2010 11:14 AM
Mbox 2 Mini causes Kernel Panic after 8 months of no issues. Panic Report Included... oneakmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-09-2010 08:52 AM
Kernel Panic with 003 DSwartz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-04-2010 10:48 AM
Kernel Panic on Mac dreadkid08 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-29-2009 11:58 PM
I had AGAIN a Kernel Panic! ... hed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 01-05-2006 03:08 PM
