Old 06-19-2009, 02:46 AM
strangeLoop strangeLoop is offline
Default Strike - Import MIDI
I have not seen this question ask, so maybe I am really off-base, but it seems that there is no way to import a MIDI pattern into the Strike style editor.
The reason being that if I wrote several drum patterns as part of a Sibelius project and then imported the MIDI into ProTools 8, I could play Strike with the MIDI tracks in Kit mode, but it would be nice to use the complexity and pattern management features of Strike.
Russ shows how to fillet the drums out to several MIDI channels, but I would prefer to organize the drums and patterns all within Strike.
Old 06-19-2009, 03:33 AM
RussUK RussUK is offline
Default Re: Strike - Import MIDI
Not possible to import the patterns to MIDI, each pattern in Strike is effectively 3-4 patterns which gives you the complexity. You can however still vary the dynamics on your patterns. Your plan is already correct. What you could do is import a groove into Strike to change the feel.
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 06-19-2009, 10:41 AM
If you could import the basic pattern and then add the complexity it would be a whole lot easier than having to manually copy 6 or 8 patterns from a Sibelius chart.
Strike HH import Alio 45 Virtual Instruments 0 03-30-2010 03:59 PM
Can I import midi files to Strike? jlasoul Virtual Instruments 1 04-22-2008 08:03 AM
STRIKE ONLY IMPORT A LITTLE PART OF THE PERFORMANCE AMIEL Virtual Instruments 1 04-02-2008 10:51 PM
STRIKE - import midi files? Real-Time Feel Intepretation earthcorp Virtual Instruments 2 06-24-2007 05:04 PM
STRIKE? IMPORT? carnology 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-02-2006 08:31 PM
