Playback/Recording stopping immediately
Hopefully this problem isn't too complicated, but I can't seem to rectify it...
I am using pro tools 7.0 on an iBook G4. I have been recording and editing with it for about 6 months no problems. I just set up a MIDI controller for the first time and when I tried to record it would stop immediately. So I went to edit some other sessions and I am unable to playback or record ANYTHING. When I press play it immediately stops (on the transport bar it says "pause" very quickly before stopping). The same happens when I try to record. Can anyone help with this problem? Thank you! |
Re: Playback/Recording stopping immediately
I too have this problem.. Seems to be random.. When I hit play or record, the Play and Stop buttons in the transport light up briefly then nothing happens.. If I quit PT, and then open the session back up, it works fine...
I'm using: PT LE V 7.1, Mac OS 10.4.8, Dual 2.3 GHz PowerPC G5, 2.5 GB RAM |
I had this problem too. I can be working fine for an hour or so and then suddenly I can't play. Started for the first time last week. I've been using this setup for a few months now. Closing/reopening session didn't work. Changing the DAE playback buffer size to 4 from 2 got it working again. I switched it back to 2 and it's working again so far...
Anybody else see this or have solutions/know why it does this? PT 7.1cs10 on 10.4.8 Dual 1.8 G5 with 2G RAM
--Inaam |
I have seen this here as well. In my case it seemed tied to haing ProTools running for a while. Pressing play illuminated both Stop and Play and then both turn off. I managed to briefly fix the problem by returning to the start of the session, but that wasn't a consistent fix.
Recording artist/Engineer/Producer Waves beta tester |
What make/model midi controller? There have been some known conflicts with certain midiman/midisport drivers. Have you tried downloading a new driver for the midi device?
Other than a software conflict perhaps you have PT set to wait for midi note?
************ Steven Vertel Mixing / Mastering Engineer High Rock Records & Studio NYC http://highrockrecords.com |
I have had the same problem and restarting protools is the only fix I have found. Kind of annoying when you are in the groove. I always assumed I had hit some key combination to put it into this mode, but since there's no way to tell these things easily, a restart seems to fix it.
MacBook Pro Core Duo 1.83 2 Gig RAM OS X 10.4.8 002R/PTLE 7.3.1 |
There is a button on the transport box that looks like a clock, I think. I believe that if that is enabled the transport is waiting to be triggered by a synched midi source.
As for the initial problem - we're looking into this and think we have a good idea of the cause. I'll post more info as it becomes available. |
Did digi post a fix for this? I thought I left the problem by switching back to a Mac, but I now have the same issue... Press Play (or spacebar), Stop Button flashes almost at the same time. Same thing with Record. Only sure fire work around i've found is a quick double click with the mouse... well almost sure fire.
Thanks!! Love this board
Little help?
Pro Tools playback starts and immediately stops | doughthedj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-10-2008 08:13 AM |
protools 7.3 playback stop immediately | shinaz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-15-2007 10:01 AM |
Protools Playback starts and then stops immediately | sixgroovenine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-09-2007 02:07 PM |
How To Start Recording Immediately PT 7.3.1 XP | bigtex999 | Tips & Tricks | 3 | 04-23-2007 04:56 PM |
Playback Issue! Play starts then stops immediately | RSSstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 51 | 04-25-2006 11:02 AM |
