Old 01-02-2021, 04:12 PM
bonzerboy bonzerboy is offline
Default Compression Question
When using parallel compression with an AUX track is there a rule of maxing out the send from the Audi track or having the fader maxes or zero and then adjusting the send? Curious if there is a rule to this ?
Wow am I groovy or what
Old 01-02-2021, 04:17 PM
Sardi Sardi is offline
Default Re: Compression Question
There are no ‘rules’ with these kind of things.
Workflow wise, it makes more sense to send the full signal and adjust to taste the wet dry with the aux fader. When you have a mix going, you don’t really wanna be popping open the sends to see/adjust things.
Old 01-02-2021, 04:28 PM
Sometimes send more than one like a kick and a snare or set up a plug in for color. I find my self going back and forth
Compression question jacub Tips & Tricks 6 02-17-2009 12:37 PM
Question about Compression . Pop-cycle General Discussion 1 08-17-2005 05:28 PM
Compression question pixel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-12-2004 10:21 AM
Bus compression question jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-07-2003 11:42 AM
compression question KnuckleHead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-11-2003 11:11 AM
