Old 09-19-2009, 10:06 AM
Arya44 Arya44 is offline
Default ProTools User Wishlist / Shortcut for Selecting attached regions?
Hi there,
Do you know if there is a ProTools wish list in Digi website?
It is good to have triple click selecting everything in the track but wouldn't it make sense if they would add "selecting all attached regions" let's say with command + triple click? PT selects region with double click but I found quite a few cases when I have multiple regions crossfaded to each other and I have to change automation for the whole piece or move all attached regions together and I need to do it in two steps.
Cheers.
Old 09-19-2009, 02:16 PM
Stig Eliassen's Avatar
Default Re: ProTools User Wishlist / Shortcut for Selecting attached regions?
Not entirely sure what you mean, but you can select/add regions from the keyboard.
  • Ctrl-Tab (selects next region)
  • Ctrl-Option-Tab (selects previous region)
  • Ctrl-Shift-Tab (extends selection to next region)
  • Ctrl-Option-Shift-Tab (extends selection to previous region)
Cool stuff, and you can work fast this way.
Old 09-20-2009, 06:48 AM
Drew Mazurek's Avatar
In addition to Stig's suggestions, you may want to look into Region Grouping once you hit the mix stage. This would allow you to turn each section of regions into "one big region" and allow you to select these with a double click.
www.drewmazurek.com
Shortcut for selecting clip simonyeah Pro Tools 10 2 01-18-2014 12:43 PM
PT 10 | shortcut for selecting next/previous clip johannes1 Tips & Tricks 2 10-17-2013 03:34 AM
Keyboard shortcut for selecting tracks Mack Truck macOS 2 09-05-2013 05:50 AM
Keyboard shortcut for selecting playlists kevinb511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-30-2007 03:26 AM
Shortcut for selecting all regions Dopamine Tips & Tricks 6 05-15-2005 08:19 PM
