Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
  #81
Old 06-30-2022, 03:47 PM
Evermore Evermore is offline
Default Re: Sampling Rounding Bug and Workarounds - Pro Tools 2020.3
Hey All,
It's been a while. I noticed that Pro Tools 2022.6 was just released and read the release notes.
Did Avid finally fix the plaguing Sampling Rounding issue for midi?
Notes:
MIDI
-Incorrect overlap shadows on MIDI clips are no longer displayed at session open (PT-279272)
-MIDI notes should no longer disappear when copy/pasting MIDI clips (PT-278475)
-Nudged MIDI clips should no longer incorrectly merge into other clips under certain conditions, and will correctly overwrite instead (PT-267098)
-When clips are edited in Grid mode, the correct MIDI notes at the clip boundaries should now be included (PT-261344)
-MIDI clips and notes should no longer shift positions and lengths when duplicated in the timeline (PT-254223)
-Dragging MIDI clips should no longer elongate them by 1 sample, which was causing notes at the start of the following bar/beat to be overwritten (PT-245969)
-There should no longer be MIDI notes that do not respond to editing commands, nor copy when dragged instead of being moved (PT-242595)
-Copy/Pasting or duplicating a MIDI clip should no longer result in the length of some of the notes being changed (PT-236760)
-MIDI notes no longer erroneously move when selecting clips (PT-273060)
Looks like I'll be doing some extensive testing with a Trial. If anyone else can provide some testing, I would kindly appreciate it. Fingers crossed!
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Apogee Symphony IO mkii
  #82
Old 06-30-2022, 04:53 PM
XJENSEN XJENSEN is offline
Originally Posted by Evermore View Post
Hey All,
Notes:
MIDI
Wow! If this is true, I'll reinstate. Long overdue, but critical to integrated music composition in Pro Tools. Fingers crossed!
Pro Tools 2020.1 off the wall Pro Tools 2019 141 11-28-2022 01:59 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
Solutions and Workarounds For Accel TDM Studios To Use Pro Tools 11 relaxo Pro Tools 11 16 04-20-2014 05:53 AM
sample rounding error in pro tools 10??? DarkDayz Pro Tools 10 6 11-02-2011 03:22 AM
