Old 09-07-2006, 01:42 PM
Irl Sanders Irl Sanders is offline
Default Import Audio dialog , Can\'t select or play audio
How come if I use the "search" in the Import Audio dialog, I then can't audition or select for import the returned files?
PT or Mac problem?
Irl Sanders
Music Editor
LA, CA, USA
Old 09-07-2006, 01:49 PM
Default Re: Import Audio dialog , Can\'t select or play audio
BTW,
PT7.2
OS10.4.7
Irl Sanders
Music Editor
LA, CA, USA
Old 09-07-2006, 01:59 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Same here, 7.2
noise | jimlongo
Old 09-07-2006, 02:47 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
We're running 7.2 and it's working like it did with 6.9.3! We have all of our SFX loaded onto a G4 in our machine room where everyone can access it via the network. Even with the G4 only have 100Mb Ethernet, it auditions and imports just fine.
Not sure what else I can tell you....
_____________________________________
I spoke too soon! We don't use the search function as it would take FOREVER to search through 150GB+ of sound effects! Sorry... normal IMPORT works fine but I'm having the same problem as you using SEARCH.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 09-07-2006, 03:00 PM
WildHoney WildHoney is offline
Yeah, it's only a problem if you use Search from the Import Dialogue window. Normal browsing auditions fine. I have the same problem here on 7.1cs9. Weak.
Old 09-07-2006, 03:05 PM
I also wonder when the mp3 import problem will be fixed -
if you drag-n-drop an mp3 into the session, you then can't save the session.
Irl Sanders
Music Editor
LA, CA, USA
Old 10-02-2006, 04:32 PM
PT or Mac problem?
Hellooooo, Digi?
Irl Sanders
Music Editor
LA, CA, USA
Old 10-03-2006, 07:39 AM
MindTheBollocks MindTheBollocks is offline
I reported the same problem in PT7 LE - no comments from digi yet
Old 10-03-2006, 08:10 AM
DigiTechSupt's Avatar
If you're on 7.2, it's fixed in the cs1 release. An update for 7.1 is coming shortly.
Avid Audio Tech Support
Support FAQ
Old 10-03-2006, 08:14 AM
Yes, we are aware of this problem. The search function is an OS operation and using it disabled auditioning. We're looking at ways to work around this, but I do not have any specifics on when this may be implemented.
Support FAQ
Searching in Import Audio Dialog Submersible Pro Tools TDM Systems (Mac) 2 05-20-2007 01:22 PM
I cant preview audio in digibase or import audio dialog. sammyfarr Pro Tools TDM Systems (Mac) 0 03-29-2007 01:16 AM
Audio import dialog box - no preview audio Sofine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-23-2002 03:04 AM
5.1.1 Import Audio Dialog - another change? barden Pro Tools TDM Systems (Mac) 1 06-29-2001 02:35 PM
Import Audio dialog PROBLEM jimlongo Pro Tools TDM Systems (Mac) 1 03-12-2001 03:32 PM
