Old 11-11-2004, 09:13 AM
wolfdavis wolfdavis is offline
Default Edit pack keyboard NF with PC key pad in 6.4.1
You may all know this already, but it has been found that the USB keyboard in the Edit pack does not function with the Pro Control 10 key in PTs V6.4.1cs1. There is appearently a bug that kills communication between ethernet and USB wich makes it very hard to use command keys with the procontrol key pad unless you get an extended keyboard and put it on top of the current edit pack key pad. (Pretty tough anyway since you would be smashing down all the keys of the edit pack keyboard.)
This bug is really irritating if you own an edit pack and a ProControl and use the keyboard.
Wait... Isn't that the reason most people bought the edit pack besides the surround panners?
Speak up on the DUC if you want this fixed!
Thanks!
Justin Davis
Rocky Mountain Recorders
Is Procontrol/edit pack/ fader pack still supported vudoo Pro Tools 9 8 11-06-2010 08:19 PM
Keyboard equivalent to edit pack machine track arm macaholic ProControl, Control|24, Command|8 0 07-24-2006 02:52 PM
Edit Pack keyboard and trackball tobascosound ProControl, Control|24, Command|8 0 05-29-2005 07:26 AM
Edit Pack Keyboard aliensound ProControl, Control|24, Command|8 1 01-28-2004 11:29 PM
Track ball and keyboard freeze (edit pack) midilandiaMex ProControl, Control|24, Command|8 3 04-21-2001 12:27 AM
