protools mbox with protoolsLe trouble
hello everybody
I have a powerbook g4 800 512 mo with mbox usb and running with protools with about 6 plug ins i have the message: " CPU usage is holding off USB audio,remove some plug,delete some tracks or..." i increase my h/w buffer size like prerconised, but the pbook can't run with these all plugs Isn't it strange to be bugged with just 6 plugs on pro tools, questions : 1) would i have best results on firewire dd or have i to change system parameters?whiwh? 1) does logic audio'or DP3' s plug ins less exigent than protools and let me work easier Thanks a lot for your response -do you have the same trouble on 800 with 6,7 plugs ?? |
Re: protools mbox with protoolsLe trouble
When working with host-based systems (such as PT LE), there is always a trade-off between track count, edit density, plug-in count, inserts/busses, session length, etc (including DigiStudio functions). The more of one that you have, the less of the others you can use.
Reverbs and especially third party plug-ins require much more CPU horsepower than dynamics-type plug-ins such as Compressors and Gates. Based on the above information, what type of plug-ins are you running when this message is posted? Brent |
theloy,
im running mbox on a titanium 500 w/ 512 mb ram and am getting 24 tracks/24 bit w/ about 10-12 mono plugs( from waves to stock to couple of autotunes) and im hitting about 60% on the cpu meter. i also have two stereo aux tracks w/ Dverb/ waves supertap. when i got the mbox, i did a fresh install w/ OS 9.2.2 and then mbox software. PLUS all of this is running off of the internal drive, both audio and apps.
CHUCKNKD [url=www.myspace.com/chuckbutlermusic[/url] |
24 tracks with 12 plugins? how???
it regards protools le 5.2
plug ins used: - sansamp * 2 tracks - bomb factory * 3 tracks - filerbank rtas e6 mono * 2 tracks - realverb rtas stereo * 1 in aux input track soundcard : mbox in 24 bits /44100/hw buffer to 1024/cpu usage limit 85 % - cash memory:512 ko/virtual memory off i am disapointed regarding to my configuration |
the sans amp is a HOG to the cpu. you might go w/ the audiosuite version of that one.
OK, i just pulled up one of my sessions on my Tibook and ive got: 24 tracks/ 24 bit 6 mono digirack compressors 6 mono digirack 1 band eqs 2 mono Lo-fis 1 autotune 1 stereo aux track w/ stereo D-verb 1 stereo aux track w/ Waves supertap delay(2tap) 1 stereo aux track w/ Waves enigma 1 master fader track w/ maxim this all runs at around 70 % cpu and my system meter is barely even making an appearance.(what does the system meter actually tell you anyway?)
Although its cool to stick an RTAS plug in on a track and leave it there, I'd try to get into the audiosuite mindset, and only use RTAS for stuff that has no audiosuite equivalent (GRM Tools comes to mind) or things that you're automating/tweaking constantly. |
Trouble Using an Mbox 1 with Windows Vista and Protools 7.4 | thabigchief | Pro Tools M-Powered (Win) | 0 | 08-29-2008 10:58 PM |
Trouble getting MBOX with PROTOOLS LE to work | guitarmanII | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-06-2007 07:59 PM |
MBox / ProTools Trouble... | cutsmarked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 10-05-2004 07:19 PM |
MBOX+protoolsLE 6.1.1:SunthCore Error+output noise | french-whisper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-23-2004 08:54 AM |
Can anyone help me w/ my Mbox/ProToolsLE? Anyone? Please! | AlejandroVillarino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-04-2003 07:33 PM |
