Direct Box & Line Leveler for Keyboard Modules
Excluding pre-amps, what purchases do I need to make to connect 3 keyboard modules to the 192 I/O?
Will a 4 channel DI box work, and should it be active or passive? Also, do I need a line leveler? Thanks
Dean |
Re: Direct Box & Line Leveler for Keyboard Modules
if you use an active di it will need some sort of power source. Some models are battery powered if a 48v dc power is not available.
I see a lot of keyboard players using submixers for level control although you can do some level setting from the output of the synth itself good luck
Running Pro Tools 2021.12 Main System 2020 M1 Macbook pro 13 inch / 16MB Ram / 1TB SSD / Big Sur Future System 2021 14inch M1 Pro / 16MB Ram / 512 / Monterrey |
I just run all mine directly in to the -10 inputs of the 192 I/O.
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
I use my Digi PRE but if I didn't have that I would just run direct into the 192 I/O as long as they were short cable runs.
- Jason |
Thanks for your suggestions. I was able to purchase a D-Sub cable to male and connect one end to the C24, the other, the 192.
Dean |
Keyboard Shortcut to tab cursor to next grid line? | stpete111 | Pro Tools 10 | 13 | 03-19-2020 11:37 AM |
Line 6 Keyboard/Audio Interface | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-13-2006 02:58 PM |
Leveler | Joe Evans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-04-2005 09:48 PM |
direct recording , line 6 or direct box? | dannypassenger | General Discussion | 3 | 01-12-2005 07:17 PM |
Mackie 1604 VLZ PRO -Direct Line Outs | Digitalkidd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 11-27-2004 05:45 PM |
