PC doesn't recognize MBox 2
Okay, I'm getting really mad. My Mac recently died so I decided to build my own PC. It ran nice and smooth and didn't give me any problems...until I tried to install Pro Tools. At first I tried installing my original 6.7 disc, but the software couldn't recognize the MBox 2. At the point where I was instructed to connect the hardware and click ok, I received a blue screen memory dump. When the PC rebooted, I tried to uninstall Pro Tools but couldn't. Basically I had to reformat my hard drive and reinstall Windows to get rid of it...which I did.
After a fresh Windows install, I installed 7.4 with the hardware detached from the system. Once the install was complete, I rebooted and connected the MBox 2. I received the found new hardware pop up and went through a firmware update and midi driver process. After this was complete, I received another blue screen memory dump. After another reboot everything seemed okay, but now as Pro Tools load up, I get the message saying to connect the hardware...when it is already connected. I'm losing my mind. Can someone help me with this? I'm running Windows XP Pro SP3... |
Re: PC doesn't recognize MBox 2
Hi FJ,
I'm having the same exact problem as you. But in your other post: http://duc.digidesign.com/showthread...57#post1285857 it sounds like you were able to solve your problem? Were you able to? If so, how did you fix it? Thanks |
Uninstall Pro Tools from Add/Remove Programs, then restart and install again, this time use the Getting Started Guide to walk you through a proper installation. |
Hi DigiTechSupt, Thanks for replying.
I actually am following the steps in the Getting Started Guide and have the Mbox plugged in before installation. I can't uninstall PT from Add/Remove Programs. It gives an error saying PT is already installed. So I use the PT Uninstaller program then reboot. During the installation when it asks to plug in the Mbox and click ok, (it's already plugged in so I just hit ok) an Unsigned Driver message box comes up and I click Continue Anyway. It's right at that moment the Blue Screen happens: Code:
DRIVER_IRQL_NOT_LESS_OR_EQUAL *** STOP: 0xD1 *** dalwdm.sys Judging by the error I suspected defected RAM. So I ran memtest for seven hours and all tests passed without error. As of yesterday though, I bought all new RAM and upgraded from two GB to four GB. Some specs: OS: WIN XP PRO SP2 (5.01.2600) Motherboard: Asus P5N-E SLI Chipset: nVida nForce 650i SLI SPP Proc: Intel Core 2 Duo E4600 RAM: 2 x 2048 DDR2-SDRAM Video: NVIDA GeForce 6800 HDD: 80 GB and a 400 GB DVD: SONY DVD RW DRU-720A If there's any other tips or ideas I would really appreciate it. Thanks |
Your issue sounds a little different DM... If you can't uninstall or install again... Read and try this perhaps (the link below). It saved me. I was spending a long time on this issue, until I came upon this post here. I think post #4 specifically!!!! Also, read my post that follows up. I think a folder is mentioned, but he meant "file". Just move (cut) it out of there. I think he wanted you to place it back eventually perhaps? I can't remember specifics W/O reviewing all the posts and steps. Just read them I guess. Or check out post 2. I didn't have to go to that fix myself though, as post # 4 worked for me. I'm just saying I was confused at first about that "folder" reference when indeed it was a file.
Good luck!~
My PC facts |
Thanks Balty.
I tried it out and unfortunately I got the same error. I booted into safe mode. Cut the driver. Paste on desktop. Reboot. Install PT. And then the crash when clicking on OK to install driver. dalwdm.sys Blue Screen. I even tried installing PT in Safe mode. Even though I got some other errors during the install it did get past the dalwdm.sys error and was able to finish the installation. But when I rebooted i got the blue screen on start up. Thanks though |
I tried every USB port. Even detaching everything except my USB mouse.
No luck. |
Some more tests. It actually does crash in Safe Mode.
In Safe Mode, when connect the Mbox the green light does not turn on. But the computer does not crash. But when I go to Device Manager and disable then enable the Mbox Audio Driver, the computer crashes. |
My Sandra Report:
Code:
SiSoftware Sandra System Host Name : User : Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 Duo CPU E4600 @ 2.40GHz Speed : 2.88GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing System System : System manufacturer System Product Name Mainboard : ASUSTeK Computer INC. P5N-E SLI Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Phoenix Technologies, LTD ASUS P5N-E SLI ACPI BIOS Revision 1301 Total Memory : 3.25GB Chipset Model : Nvidia C55 Host Bridge Front Side Bus Speed : 4x 240MHz (960MHz) Video System Adapter : NVIDIA GeForce 6800 Series GPU (256MB DDR3, 351MHz/2x1.00GHz, PCIe 1.00 x16, PS3.0, VS3.0, 2 Heads) Adapter : NVIDIA GeForce 6800 Series GPU (256MB DDR3, 351MHz/2x1.00GHz, PCIe 1.00 x16, PS3.0, VS3.0) Storage Devices Maxtor 6Y080M0 80GB (SATA, 3.5", 7200rpm, 8MB Cache) : 75GB (C:) HDS724040KLSA80 400GB (SATA150, 2.5", 7200rpm, 8MB Cache) : 373GB (E:) SONY DVD RW DRU-720A (ATA66, DVD+-RW, CD-RW, 2MB Cache) : 3GB (D:) Logical Storage Devices Hard Disk (C:) : 71GB (NTFS) @ Maxtor 6Y080M0 80GB (SATA, 3.5", 22160rpm, 8MB Cache) Data (E:) : 373GB (NTFS) @ HDS724040KLSA80 400GB (SATA150, 2.5", 7200rpm, 8MB Cache) Pro Tools LE (D:) : 3GB (CDFS) @ SONY DVD RW DRU-720A (ATA66, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS A8N-VM CSM Mainboard Audio Device : ASUS MCP51 High Definition Audio Audio Codec : Realtek Semiconductor 883 High Definition Audio Serial Port(s) : 1 Disk Controller : ASUS A8N-VM CSM Mainboard Disk Controller : ASUS A8N-VM CSM Mainboard Disk Controller : ASUS A8N-VM CSM Mainboard Disk Controller : ASUS JMicron 20360/20363 AHCI Controller USB Controller 1 : ASUS A8N-VM CSM Mainboard USB Controller 2 : ASUS A8N-VM CSM Mainboard FireWire/1394 Controller 1 : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller System SMBus Controller 1 : nVidia MCP5+ SMBus 1 System SMBus Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Microsoft Office Document Image Writer Driver (200x200) Printer : Amyuni PDF Converter 2.07 (1200x1200, Parallel, Colour) Printer : HP DeskJet 710C (300x300, Colour) Network Services Network Adapter : NVIDIA nForce Networking Controller #2 - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 2) Platform Compliance : x86 . |
Pro Tools doesn't recognize MBox Pro 3rd Gen | saunite | Windows | 0 | 06-26-2012 09:13 AM |
Pro tools 9 does not recognize Mbox 3 | luchis21c | Windows | 3 | 04-14-2012 10:38 AM |
Pro Tools Doesn't Recognize MBox 2 Pro | RBM01991 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-24-2010 10:27 AM |
MBox 2 Won't Recognize? Help..! | northpilot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-26-2007 08:35 PM |
Computer does not recognize Mbox | Brodierock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-26-2003 06:06 PM |
