Will 882 16 bit version transfer 24 bit S/PDIF?
Could anyone tell me if the old 16 bit 882 interface will transfer audio at 24 bit through S/PDIF? I am not clear from the digi docs between the 16 bit and 20 bit versions of the 882. The 20 bit version doc does not specify this. http://akmedia.digidesign.com/suppor...uide_29361.pdf and I have not, so far, been able to find a guide for the 16 bit 882. I was wondering if it would be possible with an optical to co ax converter, or two, to get 24 bit digital audio to/from the built in optical S/PDIF on a MB pro with the kind of optical lead that used to come with portable minidisk players. Does anyone have any experience of doing this, or something similar? Thanks BD |
Re: Will 882 16 bit version transfer 24 bit S/PDIF?
You are referring to the 1U rackmount 882 that works with PTIII/Mix, right?
I'm pretty sure that all of the AES/EBU and SPDIF connections on these interfaces are 24 bit. I know for sure this is true on the 888s, and should be true of the 882s as well. The 882-16 or 882-20 just designates the ADA converters bit depth. I have used a HOSA ODL-312 to convert the mac's optical i/o to AES/EBU. One thing I'll caution you on is not all macs with the digital i/o can sync to an external clock. The option for clock source may remained grayed out in audio midi setup on some macs. |
Hi John,
Thanks for the reply. It's good to know the 882 16 will do 24 bit if it's the one I think - rack mount 1U as you say. -won't see it till next week. I have just had a look and clock source is greyed out in the Audio Midi setup on my MP pro unibody late 2008. I don't know if that will change with a digital in/out plugged in but thanks for the heads up. Cheers BD |
AMIII S/PDIF in from Second Audio Card S/PDIF Out? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-04-2005 10:30 AM |
S/PDIF transfer, -9136 errors, and NASTY NOISE | jascha | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-05-2004 12:02 PM |
DAT transfer to PT using S/PDIF help! | ChrisO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-23-2002 12:07 AM |
888 interface's s/pdif input doesn't like AMIII s/pdif output | jmark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-19-2001 01:03 PM |
Track Transfer won't transfer (time code problem) | apetrocelli | Pro Tools TDM Systems (Mac) | 4 | 10-17-2000 01:49 AM |
