Old 03-22-2004, 11:34 AM
MorryC MorryC is offline
Default Broken plug in the headphone input! HELP
Has this ever happened to anyone? The tip of a 1/4 inch adaptor has broken off in the headphone input of my digi 001. It's up there good. Tweezers can't get it out as there's nothing to grab onto. Has anyone had experience removing something like this? Can I open the unit up?
I'd appreciate a quick response. Thanks in advance.
M
Old 03-22-2004, 01:29 PM
Chris Coleman Chris Coleman is offline
Default Re: Broken plug in the headphone input! HELP
M
Lemme guess...Sony's...maybe 7506's?
Four words: very thin needlenose pliers.
It's not rocket surgery
Old 03-22-2004, 01:39 PM
cleft cleft is offline
The sleeve of my Sony 7506s got stuck in my 001 last week. I was fortunately able to use needlenose pliers to get it out. Ironic that this is apparently a common problem (according to Chirs). I'm wondering now what the problem is... I guess its just a cheap 1/4" adapter. I hope that an alternate adapter from RadioShak won't have the same issues... though they don't screw on to the headphone plug. Any ideas on a better replacement?
Sorry I don't have any better advice than the pliers.
Old 03-22-2004, 02:01 PM
sean shannon's Avatar
sean shannon sean shannon is offline
magnet?
Check your mix in mono.
www.mixingtheband.com
Old 03-22-2004, 02:31 PM
leftalive leftalive is offline
Opening that sucker up is going to be an extreme pain in the ass, so whatever you do save that for last. The needle nose plier thing should work. There has to be SOMETHING left to grab onto.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 03-22-2004, 02:55 PM
Michael Cottrell Michael Cottrell is offline
This has happened to me a few times in my career. What you need to do is go to a pro-electronics supply store and get a very very narrow pair of needle nose pliers. They make really thin and pointy versions that work quite nicely. I checked Radio Hack store a number of times but never found any that were thin enough to fit in there.
Hope this helps.
Old 03-22-2004, 07:26 PM
Thanks, and I'll definately be looking for a pair of those extremely thin needle-nose...but before I got a reply here (or got through the labyrinth of Digidesign's phone support) I panicked and brought the unit to a pro audio repair shop. He looked at it and said "Wow, man, you're f**ked." And that's a direct quote. Anyway, my 001 is in the shop tonight, and it's probably going to cost me in excess of $100 to get the damn thing out. This place came highly recommended by a trusted source, so I'm trusting that he's right and it's not a simple matter of just pulling it out with needle-nose pliers. But after reading your responses, I can't help but think I might be getting taken for a little ride...
Old 03-22-2004, 10:34 PM
Well, either way, you're definitely f**ked now.
sorry mate
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
Pro Tools 12.4
A loaf of bread
A stick of butter
Old 03-22-2004, 11:57 PM
JLMarechal JLMarechal is offline
Which not using fast glue on a tip ?
Jean-Luc Marechal
G4 DP DualBoot 1.25 GHz / Digi 001
Old 03-23-2004, 01:32 PM
mikemaas mikemaas is offline
morryC, I had this same thing happen a couple of months back... I tried the super glue route to no avail. This was off a pair of AKG K240's...
I took it to an audio/music gear store and the tech guy drilled into the tip a little ways with a small bit - stopped the drill and pulled it right out. Charged me $35.
good luck man,
Mike
Studio 17
Headphone jack broken. Philuk Eleven Rack 6 07-28-2013 07:36 PM
Broken headphone input jack Command8 TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-31-2012 07:56 PM
002 Headphone Jack broken cyjamman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-12-2009 09:51 AM
Broken headphone jack.. (what would be cheaper)? tec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-20-2007 10:10 AM
broken headphone amp? stewie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-09-2005 04:00 PM
