Old 07-15-2002, 04:06 PM
andre tchmil andre tchmil is offline
Default PT and logic sync
I have PT connected to logic via MTC on a seperate mac with PT as the master.
Everything is working fine except for when I make a loop in PT, (say 4 bars) logic doesn't relock at the beginning of the loop, but runs further away instead.
What to to [img]images/icons/frown.gif[/img]
Old 07-16-2002, 07:49 AM
PlugInJunky PlugInJunky is offline
Default Re: PT and logic sync
Check this out...unfortunatley MTC is not as easy to lock up. Even SMPTE takes a couple seconds to chase. It might work of you give the 4 bar loop a 2 bar pre roll. It might help if you send out Midi Beat Clock. However, its not going to lock as fast as you want. just give it some pre roll from your transport window.
DJ Jorge Felix
[email protected]
Midi Programmer/Remixer
I make beats - Love that line
Old 07-16-2002, 10:02 AM
jackruston jackruston is offline
I found it impossible to get the two to loop together. In the end I found a fantastic solution though. Give up midi alltogether and just use pt.
...unhelpful bastard aren't I...
J
Old 07-16-2002, 10:08 AM
OMG...thats funny...you know...if you like working in logic...just Program your midi there and save it on a disk as a standard midi file and open Import Midi to Track on ProTools and all your tracks from logic come right up...the only thing is you might have to assign your modules...but that doesnt take much time...make sure you send out program changes...save time turning knobs again....I love programming on my mpc...but love editing on ProTools...so I start in my Mpc load my Midi file and start editing...saves time...try that if not the hell with it...if your happy then so be....but sorry I couldnt help....latez
DJ Jorge Felix
[email protected]
how to sync PT 8 with logic 8? dotmakesmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-16-2009 03:49 AM
Sync Logic 8 w/ PT LE n2themuzic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-03-2007 11:02 AM
logic & sync IO summit01 Pro Tools TDM Systems (Mac) 2 02-24-2003 12:31 AM
Sync PT to Logic MAC via IAC, can't do it? andre maranhao Pro Tools TDM Systems (Mac) 1 04-24-2001 02:38 AM
5.0 and logic 4. will not sync sleshnyc General Discussion 0 05-23-2000 09:05 PM
