HELP! My Video Card Turned Everything Blue
I was doing some minor tweaks to my system the other night and when I restarted everything was blue as a summer sky. I tried changing color,gamma, and or contrast settings. But nothing. I cannot figure this thing out. It is an ATI Radeon 7000 dual display card. Help Please///
Thanks to all in advance, Steve |
Re: HELP! My Video Card Turned Everything Blue
First of all check your monitor if you can on another computer.
What OS are you running? If you have ME, 2000, or XP you should be able to go back to a restore point before you changed drivers. Otherwise unistall the drivers and set it back up for a standard VGA monitor. turn off the machine, reseat the video card (this may not do anything but it eliminates things) Restart the machine and resinstall the drivers again. |
If all of the above doesn't help, try starting windows in safe mode - it uses a generic video driver and may allow you to get in and reset / restore things.
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
Allen [img]images/icons/wink.gif[/img] |
also, make sure you cable is in fully, ive seen it before where a cable will become almost "cock-eyed" in the connector port, and you will lose some of your key colorization, and everything will have that "blue" hue to it.
just my advice.
Ill suffer winter alone; ten thousand miles from home... |
Will HDX card work with Blue 192's??? | corp | Pro Tools 10 | 7 | 10-24-2011 01:59 PM |
Instrument Track buttons have turned dark blue | 2hip2b4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-10-2007 05:40 PM |
Instrument Track Buttons on Mix Window have turned Dark Blue | 2hip2b4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-15-2007 04:20 PM |
I noticed All My audio files text turned blue | BigThump2007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-31-2007 06:17 PM |
usd must be turned on to pass video reference? | c-post | Tips & Tricks | 0 | 01-02-2002 09:03 AM |
