TB3 option
Hi all,
Would any be considering using the MTRX Studio with the TB3 option as I am considering purchasing one. Regards |
Re: TB3 option
Considering for what? Do you have HDX? Native PCIe? If you just want to use it as a Thunderbolt interface there are other options for you.
Re: TB3 option
Hi its2loud,
Running HD Native but looking at using this as a Thunderbolt interface via core audio and combined channel counts up to 128 if possible with DADman and the MTRX Studio. Regards |
Re: TB3 option
Combined interface with what other interface?
My professional opinion is to ditch the HD Native unless you’re using it for low latency recording. Otherwise, it buys you nothing. It just limits you. HD NATIVE only allows for 64 channels of IO in Pro Tools. MTRX Studio is limited to 64 channels via Thunderbolt. You cannot combine Pro Tools using the HD Native playback engine with the Thunderbolt core audio unless you utilize AUX I/O which is a bit janky IMO. A better way to solve your IO issue is to spend the money on something like DAD Core 256 or DAD Center AX Center. Both give you 256 channels of Thunderbolt IO. As well as Dante, MADI, and ADAT. |
Re: TB3 option
''MTRX Studio is limited to 64 channels via Thunderbolt. You cannot combine Pro Tools using the HD Native playback engine with the Thunderbolt core audio unless you utilize AUX I/O which is a bit janky IMO''.
What can using Dolby Atmos Bridge and AUX I/O offer? 64 or 128 channels of audio via TB3. Would the 64 channels of HD Native be in low latency mode if configured through AUX /IO and could I then access the 64 channels of Dante, also 16 channels of ADAT using its 512x512 matrix in DADman. Regards |
Re: TB3 option
If you’re using DAB with Pro Tools then only thing using HD Native would be the Dolby Renderer at this point for monitoring through the MTRX Studio.
You could use PTAB or DAB through Aux IO to the Renderer and back and then monitor through Pro Tools utilizing the HD Native with MTRX Studio but this is a very roundabout and latency provoking workflow when you could have direct connectivity all through Thunderbolt and DADMan Monitoring. Is the only reason you want to get MTRX Studio because you currently have HD Native? What is your current interface with the HD Native? Quote:
The Dante and ADAT is completely separate from application to application workflow. It’s merely a pipeline for input and output to the MTRX Studio. What is your ultimate goal here? |
Re: TB3 option
I have tried DAB and HD Native to the Dolby Renderer to monitor through my MTRX Studio also have looked at DAB with AUX IO however I find that these methods are somewhat complicated.
Could the TB3 option help when using Protools and the Dolby Atmos Renderer or even the AUX I/O if configured correctly and allow external patchbay routing for line in and outs into protools using TB3 within a hybrid system. Regards |
Re: TB3 option
Again, what is your ultimate end goal?
What does “AUX I/O configured correctly” mean exactly? “Allow external patchbay routing” for what? MTRX Studio? - any hardwired ins and outs of MTRX Studio would be available through either Digilink or TB3 option. What exactly is a “hybrid system”. You cannot choose both HD Native AND TB3 as your playback engine at the same time. It is one or the other. HD Native is not buying you anything here. In fact, it is only limiting you. You have HD Native. Your limitation will always be 64 channels whether it’s with Digilink or TB3 option (Again, MTRX Studio TB3 is limited to only 64 channels. |
Re: TB3 option
''The Avid MTRX Thunderbolt 3 Module enables 256 channels of native low-latency I/O connectivity and routing between multiple Core Audio- based DAWs, including Pro Tools''.
https://vintageking.com/avid-mtrx-thunderbolt-3-module |
Re: TB3 option
Its2Loud is too right.
mp3 option | mazzie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-20-2010 02:38 PM |
MP3 Option-Demo Expired-No option for aut. code | desdichadisimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-10-2006 01:24 PM |
AV Option or AV Option XL with Transoft Fibre | potatohead | Post - Surround - Video | 5 | 08-06-2001 10:24 AM |
Where is the MP3 option? 5.1 | RDOG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-09-2001 04:26 PM |
AV Option Fan required for AV Option|XL too? | Samhein | Post - Surround - Video | 3 | 08-29-2000 05:45 AM |
