Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 12-06-2021, 04:02 AM
musicman1985 musicman1985 is offline
Default Error when try to record.
Hi. I am using a iMac (21.5-inch, Late 2015) MacOS Montery and recently moved it to an external ssd. Now when I want to record my guitar I get the error message "Unable to create record files for one or more tracks. Check your disk allocation and drive permissions". I did not have this problem earlier. If anyone knows what to do please reply.
Thanks
Old 12-06-2021, 07:54 AM
junkgear's Avatar
junkgear junkgear is online now
Default Re: Error when try to record.
When you say you moved 'it' to an external SSD, what exactly do you mean?
Pro Tools First stores a working copy of your projects in a cache folder on your local drive, so if you have existing projects and moved them, there is a good chance that you have broken the file paths where Pro Tools First looks for project files.
If these projects were stored in the cloud, you can try open Pro Tools First and clicking on the down arrow next to your project in the project dashboard. From there you can choose to see the project revision history and possibly restore a copy of the project to wherever you are working out of now.
Will
System Details
Old 12-07-2021, 02:56 AM
Hi. I mean that I reinstalled macOS on external ssd, because the internal hdd was slow. I also record in Garage band and have no problems.I tried reinstalling ProTools First but get the same error message. It seems to be that ProTools First is incompatible with macOS Monterey.
Thanks
Old 12-07-2021, 06:20 AM
JFreak's Avatar
JFreak JFreak is offline
PT|first compatibility info here.
Janne
Error message when i try to record. "track could not be record-enables...." znera143 macOS 3 01-20-2012 06:17 PM
Error message when i try to record. "track could not be record-enables...." znera143 macOS 2 01-02-2012 07:41 PM
PT LE Error - Can´t record at 48 KHZ Nagi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 06-21-2009 05:15 PM
7.1 record error max cooper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2006 10:16 AM
Please Help with Error -9128 in record AaronC72 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-01-2005 02:33 PM
