Moving clips when in Volume Track View ...
Thanks for the help -
I'm running PT 11. Two questions: If I switch the Track View Selector to Volume, is it possible to still move clips in that particular track? Are there key commands to toggle between Waveform and Volume Track Views? Thanks again. -paul. |
Re: Moving clips when in Volume Track View ...
The minus sign in the alpha numerical side of your keyboard will toggle the views. There's a triangle on the lower left of your track, disclose it and you can see both volume and waveforms in parallel lanes
-paul. |
Clips are not locked, but you are no longer operating on waveform information. When in volume view you every tool is dedicated to manipulating volume, hence the grabber tool you are trying to use is now dedicated to creating break points in the fader volume curve. Just get used to the minus key.
To sort of mimic this in PT I guess I'll need to get used to setting Sync Points while in waveform view ... I'll work with the "-" key in PT. Again, thanks. -paul. |
I found what I think is a suitable option for moving clips with visible Break Points in the Waveform view.
PT View menu/Clip/Clip Gain Line. You can add Break Points to the Clip Gain line and then move the clip with the associated points. Here's a quick demo video. -paul. |
Moving volume automation on separate clips | Goombot | Pro Tools 10 | 6 | 04-22-2013 11:18 AM |
Track view toggle always reverts to volume? | tams | Pro Tools 10 | 5 | 02-25-2012 07:31 PM |
Toggle Track View not working (waveform/volume/etc) | Imgoinmad | Pro Tools 9 | 4 | 11-24-2010 04:35 PM |
Full scale volume when moving clips | Frank Kruse | Post - Surround - Video | 7 | 05-15-2008 03:49 AM |
Quick key for changing edit view to volume view in track? | postman56 | Pro Tools TDM Systems (Mac) | 4 | 11-30-2007 10:56 AM |
