HELP!!! PT level output is low going into MOTU Microbook
I will try my best to describe the problem, but know that I'm relatively new at this so I will probably botch some terminology.
My master fader reads -12db signal strength during playback in PT. The signal shrinks to -35db when sending it MOTU MicroBook as a Playback Engine. I'm getting this reading by looking the "From Host" meter level under the Output tab in CueMix. As a result, I can barely hear playback when trying to record parts since the input volume (i.e. a guitar) is much louder in comparison. I called MOTU. We reset everything to factory defaults and that didn't fix the problem. So I imagine something is happening with PT. Please help! :) |
Re: HELP!!! PT level output is low going into MOTU Microbook
Nevermind, found the problem.
The Under System Preferences>Sound>OutPut Tab I found the Motu Microbook was turned way down. It's a silly problem, but if I made this mistake, maybe someone else will. Hopefully this thread will help them. |
Fast track pro: signal on output 2 while output level at 0 | sbrunot | FireWire & USB Audio Interfaces (Mac) | 1 | 12-26-2013 04:11 PM |
Output level | Limelight | VENUE Live Sound Systems | 2 | 11-07-2010 06:54 PM |
Compressor 3 output level=input level?? | JonesH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-16-2009 05:59 PM |
Input Level vs. Output Level | MrFret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-07-2002 10:15 AM |
low output level...from 001 | john1192 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-01-2002 09:38 AM |
