Old 10-20-2012, 10:52 AM
mattpgtr mattpgtr is offline
Default PT10.3, HD2 accel Avid I/0 Hardware insert issue?
Hi, I've just upgraded my interface the Avid HD i/o, I'm running PT 10.32 on new Mac Pro with an HD2 Accel system.
I cant get my delay compensation and Hardware Inserts to work, which is reason i switched back to Avid interface. If I set up a hit on one channel, insert an insert plug in and record it back in on another channel (with no external processing) the audio is coming back earlier.
I have delay compensation switched on, have worked out the audio is 12 samples earlier but wherever i enter the figure nothing is helping.
Does anybody know a way to get this to work, I would ideally like to use my external comps and be able to record back in for parallel compression.
Any help much appreciated.
Cheers
Matt
Rather odd hardware insert issue: 003R In the Van FireWire & USB Audio Interfaces (Mac) 4 09-09-2013 12:04 AM
Hardware insert with non-Avid/Digi interface? ChuckS Pro Tools 10 3 03-06-2012 06:38 PM
Hardware Insert Issue Tyderian Pro Tools 9 7 01-30-2012 07:36 AM
Hardware Insert Bussing Issue in 8.01 Siegfried Meier Pro Tools TDM Systems (Mac) 1 10-11-2009 01:37 PM
Hardware Insert Issue-Error Message on I/O imcivor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-30-2004 08:10 AM
