Delay compensation question...?
Hello,
I just did a major blazing overall to my PC, AMD 3500+, 10K Raptors drives, 2GB high performance low latency ram, and fresh new install of Pro Tools. Now when i add plug-ins to my tracks and CTRL Click on the faders to go thru the 3 different displays (volume, peak, delay ) i always get "0" in the delay even if i add like 5 plug-ins on the tracks, i could add 5 reverbs and still get "0", am i missing something??? is there a preference setting that needs to be changed?... the display changes for the "Volume & Peak". Do i need something else "clicked" ????? Would this new system upgrade have anything to do with it? maybe eliminating a delay now the speed of the system has been boosted and overhauled for major performance??? Thanks, Cory C |
Re: Delay compensation question...?
Cool.. thanks!!!
RTAS plug-ins should not report anything when you Control click to display the delay.. that's a TDM only function.. and if a value is reported for an RTAS plug-in it will screw up the timing for the track if that plug-in is used as an RTAS version on a TDM system using ADC. ADC on the TDM system will use that value and delay the tracks incorrectly.
Rail
Re: Delay compensation question...? RAIL ?
Please take a look at THIS PICTURE OF LE ChannelStrip always reports a dly of 16, ... the accumulation of plugins on the VoxComp channel, is reporting 144. Waves Mono Rvox by itself RTAS always reports 64. In the sesion above, on a track like the vocal track, that has a series of latency reporting RTAS combined, I can usually hear the track "Fall out of the pocket a bit" and by nudging the audio by the number indicated, I've always felt that (or thought) it returned back to where it should sit in the track. Is that correct ? I do this tons and wonder now, if I am just imagining it by analizing the nuances of the performance on a track, because of the "Psycology" of having many plugins on a track, and "Expecting" latency ? Please elaborate a bit on the pic linked above, and weather or not PT 6.7LE automaticly compensates for RTAS DLY (OR if there really "IS" Delay incurred by these plugins (I'm wondering if your statement "RTAS plug-ins should not report anything when you Control click to display the delay" intimated that ALL RTAS plugins do NOT introduce latency) in which case there would be no compensation in 6.7, it'd obvioustly be un neccisary. You know, I could do the whole, record to another track with the plugin's through a Bus, and check the sample accuracy, however 1. I'm too tired... and 2. You know this stuff inside out, and your explanation regardless of the outcome, especially about the dly reported by these plugins, will be way more informative.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
The Reference Manual clearly states that the delay is only for TDM plug-ins... Some RTAS plug-ins will induce a delay, and most won't... some like the URS EQ's used to report a 4 sample delay for the RTAS versions as well (while they incur no delay when used as RTAS)... so when used in TDM 6.4 or later with ADC enabled would place the audio 4 samples too early. RTAS plug-ins which do incur a delay which matches the TDM versions will be fine with ADC, however don't assume that the value is correct for RTAS.
Rail
Thanks Rail.
Delay Compensation Question | Roulette Records | Pro Tools HDX & HD Native Systems (Mac) | 14 | 10-13-2013 08:03 AM |
question about delay compensation | dbvoyager | Pro Tools 10 | 2 | 04-28-2012 11:48 AM |
New guy question on Delay Compensation | PMcC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 23 | 07-25-2009 01:29 PM |
Delay compensation question... | AudioMaster | Post - Surround - Video | 5 | 02-24-2009 12:58 AM |
Delay Compensation Question | R-Blitz | Pro Tools TDM Systems (Mac) | 5 | 11-24-2005 09:30 AM |
