Old 08-14-2006, 10:03 AM
Dan Pinder Dan Pinder is offline
Default 7.2 new behaviour I don\'t like
I need to read the What's New again but is this a new editing behaviour or simply a bug: Normally, if you have a gap between two regions you can tab to the end of one region, hold shift and tab to the beginning of the 2nd region and it creates a selection in the blank space between them, which is handy for creating a crossfade in there or to select time which you would like to shuffle-out. I cannot do this anymore without 7.2 selecting both the blank space AND the entire region to the right of it. This is seriously NOT COOL.
Can anyone confirm?
G5 dual 2.7
2.5GB RAM
10.4.6
Old 08-14-2006, 10:31 AM
filmixer filmixer is offline
Default Re: 7.2 new behaviour I don\'t like
> if you have a gap between two regions you can tab to the end of one region, hold shift and tab to the beginning of the 2nd region and it creates a selection in the blank space between them<
This hasn't changed in 7.2 and is working fine on my systems. You should be able to "Shift-Tab" between regions even if Tab-To-Transient is on. I would trash prefs etc. and see if that solves it.
Mark Ettel C.A.S.
Old 08-14-2006, 11:23 AM
It's weird—I tried it in another session and it was fine. Must be the drugs...
Old 08-14-2006, 11:50 AM
RobMacki RobMacki is offline
Fine here.
One thing I have noticed on my new Mac PT Keyboard is a dbl entry on the keys in focus commands mode.
It will behave like a bug.
I may need to return this kbd.
Just thought I'd mention that as a possibility.
Old 08-14-2006, 12:06 PM
Steve MacMillan Steve MacMillan is offline
I have seen this behaviour too, and then later when I tried to find a consistant way to make this happen it worked normally. There is definately a bug in there somewhere.
STeve
macmandigital.com
Still 003 strange behaviour... brian brilliant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-31-2007 12:26 PM
preferences behaviour! Pedro perez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-20-2007 07:37 PM
Odd Reverb One behaviour Mitch Griffin Pro Tools TDM Systems (Mac) 2 08-20-2004 06:57 AM
Bug in channelmatrix -behaviour since 6.4 Mano ProControl, Control|24, Command|8 2 08-06-2004 11:36 AM
Weird L1 behaviour... Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-02-2002 03:53 PM
